AgroSense_4 Channel Relay LoRaWAN® Class C
It is based 4 high-load relays that support max 20A@125V AC, make it possible for users to control 4 channel loads, such as Fan,Lamp
Starting from
$19.80
Makerfabs has 1483 orders / 36reviews
Ships from China
This AgroSense 4-Channel LoRaWAN® Relay is designed for LoRaWAN remote control from cloud via LoRaWAN Class C. It is based 4 high-load relays that support max 20A@125V AC, make it possible for users to control 4 channel loads, such as Fan/door/lights, On/Off, via standard LoRaWAN Class C from Cloud service. Also 2 channel analog inputs(0~5V) support common sensor inputs, and on-board temperature and humidity sensor(AHT20) for field application environment detection, for fire/dangerous detections.
General Parameters
Product ModelAGLW4R01
Temperature Measurement Range-40°C ~80°C
Temperature Measurement Accuracy±0.5°C
Temperature Resolution0.1°C
Humidity Measurement Range0%-100% RH
Humidity Measurement Accuracy±2>#/td###
Humidity Resolution0.024% RH
ADC Measurement Range12-bit ADC
ADC Measurement Accuracy1/4096
ADC channel count2
Relay Power SupplyDC 24V
Relay Contact Rating20A/125V
Relay channel count4
Wireless Parameters
Communication ProtocolStandard LoRaWAN® protocol V1.0.3
Network Access/Operating ModeOTAA Class C
MAX Transmit Power22dBm
Receiver Sensitivity-137dBm/125kHz SF=12
Frequency BandEU868/US915
Physical Parameters
Power SupplyDC 24V
Operating Temperature-40°C ~85°C
Dimensions95 × 90 × 40 mm
MountingWall Mounting
View project log
