EIWA first operative hardware implementation
PCBs realization for the flight test phase of my project EIWA
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I've completed the design and the manufacturing of the two main boards for my EIWA system.
One of the board will the ground station to receive the telemetry from the aircraft while the second in the so called "SCH" System Central Hub, the board designed to collect the data
from the several sensors modules on the radio-controlled model and elaborate them prior to be showed on the ground by the MatLab interface.
The boards have been kindly provided by PCBWay, check it out on this website: https://www.pcbway.com/ if you are searching for a fast and reliable PCB prototypes provider!
