Musical Mat Runway
A runway of tiles that wheelchairs can run over or add pressure to the tiles to make different noise.
0 followers
A runway of tiles that wheelchairs can run over/add pressure to the tiles to make different noise. It's a way for everyone to have fun with something, whether or not they have strong legs.
This project is meant to be assistive technology for people in wheelchairs to help them communicate with other children and also act as a tool just to have fun like anyone else would. We decided that we wanted to try to make it as subtle as possible to not make it stick out as "different" or anything. The final product would be a group of tiles (load cell in the prototype), a speaker, and some of the boards to hold the code to play the music & everything.
4/16/25
JPEG Image - 179.73 kB - 04/16/2025 at 21:14
Preview
  • Week May 5-9
    Maddox C.4 days ago 0 comments
    This week we had a lot of troubleshooting once again with our hardware, we had to solder some wires to the RP2040 and fix a couple issues with our SD card. We've also been working on a tri-fold that showcases our project.
  • April 27 - May 2
    Maddox C.05/02/2025 at 21:44 0 comments
    This week, we mainly worked on our code and a little bit of troubleshooting with our load cell and RP2040 but other than that we don't have anything else to complete
  • April 21-25
    Maddox C.04/25/2025 at 22:00 0 comments
    This week we mainly worked on things on the computer, the highest priority being our code and troubleshooting, while other things like setting up the rest of our Hackaday project and making sure everything looks good. There isn't much else to say this week.
  • Week April 14-18
    Maddox C.04/16/2025 at 21:10 0 comments
    This week, we acquired a new board called the Adafruit feather RP2040 for our load cell and NAU7802 Bridge & Gauge Sensors. The RP2040 will be hooked up to two speakers so we can make noise by applying pressure to the load cell.
View all 4 project logs
  • 1
    Acquire parts
    Acquire all parts listed in components section
  • 2
    Assemble Music Maker & Amplifier
    Take your RP2040 Music Maker and connect it to the amplifier using the yellow, red and blue wires.
  • 3
    Continue assembly of amplifier and add load cell
    With the wire clamps on the other side of the amplifier, loosen the screws and then slot in the wires on your load cell and then tighten the screws to secure your wires in the amplifier.
View all 5 instructions
