The Openterface Mini-KVM Lite Series is a streamlined, ultra-portable KVM-over-USB solution designed for IT professionals, developers, and tech enthusiasts who require quick, reliable access to headless systems. Building upon the success of the original Openterface Mini-KVM, the Lite Series eliminates the need for additional video cables by integrating HDMI and VGA connectors directly into the device.
Key Features:
- Integrated Connectors: Choose between HDMI Male or VGA Male versions for direct plug-in, reducing setup time and cable clutter.
- Plug-and-Play: No software installation required on the target device; simply connect via USB and HDMI/VGA.
- Cross-Platform Host Support: Compatible with Windows, macOS, Linux, and Android host systems.
- BIOS-Level Access: Gain control over target devices even before the operating system loads.
- Compact Design: Smaller and more portable than its predecessor, making it ideal for on-the-go troubleshooting.
