20200731 : cleanup of many dead links...
This page serves 2 purposes :
- share the resources I have created for all those articles (because http://ygdes.com/sources/ and http://ygdes.com/GHDL/ are not the most convenient)
- maintain a somewhat not-too-inaccurate bibliography (since the editor's site often lags and/or misses a thing or two)
I also try to track those articles I asked the editor to publish under CC (and which he forgot).
Some files are available on the web (without the publisher's approval), I provide the links for the sake of completeness.
The publisher maintains its own (incomplete) list at https://connect.ed-diamond.com/auteur/Guidon-Yann
Pub'd |
Title |
Mag. |
pp |
CC |
| 1996.02 | "SOUFFLERIE NUMERIQUE SANS CALCUL" | Pascalissime#64 | 16-42 | NO |
| 1999 | about the F-CPU project | GLMF#15 | ||
| 2001 | "Développer en VHDL sous Linux" (using Vanilla VHDL & Simili) | GLMF#36 | ||
| 2001 | a little Xlib-based tool that monitors the CPU load | Linux Loader #2 |
| 2004.05 | "GDUPS ou la chasse aux fichiers dupliqués" see #gdups for the most recent version |
GLMF#61 | 56-65 | NO |
| 2005.1 | "Installation, préparation, entretien et récupération des disques durs" Groom and mourn you HDD (my first cover) |
GLMF#68 | 30-45 | NO |
| 2005.6 | "Introduction à la compression de données : validation d'un benchmark libre" Characteristics of a free benchmark for lossless sound compression (DSP and spectra for dummies) |
GLMF#73 | 16-25 | NO |
| 2005.7 | "Introduction à la compression de données : mise en évidence de l'entropie" Entropy exposed (Shannon's principles, coding theory, the nature of information...) |
GLMF#74 | 46-60 | NO |
| 2005.9 | "Tuning de code : optimisation d’un filtre UNIX sous Linux" Tuning disk read and write bandwidth (benchmarking of the Linux Kernel with different R/W buffer sizes, multithreaded solutions, "pipe buffer" Unix utility) |
GLMF#75 | 72-83 | NO |
| 2005.12 | "Réalisation du CRC pour le conteneur MDS" | GLMF#78 | 70-86 | NO |
| 2006.3 | "Les nombres pseudo-aléatoires pour les nuls (enfin, pas trop quand même)" Understanding Pseudo-Random Number Generators (Galois fields, primitive polynomials, optimized PRNG: 500MB/s, P3@700MHz) |
GLMF#81 | 64-76 | NO (but was ?) |
| 2006.6 | "Adieu à Uqbar, le supercluster vectoriel de l’IDRIS" (Interviews, introduction to scientific HPC, vector vs SMP...) | GLMF#84 | 6-18 | NO |
| 2006.7 | "Sciences/Théorie de l'information : propriétés et dérivés des CRC et LFSR" (Galois vs Fibonacci configurations etc.) |
GLMF#85 | 84-93 | NO |
| ? | "Quelques techniques d'optimisation en C" | ? | ||
| 2007.04 | "Conception de l'algorithme CRC16-64 (première partie : le scanner/balayage à haute vitesse)" | GLMF#93 | ||
| 2007.05 | "Personnalisation (un peu brutale) du système de login et des terminaux virtuels" | GLMF#94 | ||
| 2007.07 | "tGFSR32x4 : un nouvel algorithme pour la signature de données" | GLMF#96 | ||
| 2007.10 | "Prologue et épilogue de l'algorithme de signature rapide tGFSR32x4" | GLMF#98 | 86- | |
| 2007.11 | "Algorithme de fragmentation pour MDS" describes a smart algorithm to prevent the "tiny remainder" problem when cutting blocks into smaller ones | GLMF#99 | 86-93 | WAS |
| 2008.05 | "Accéder aux fichiers en JavaScript (ou le Cross-Site Scripting utile)" (a dirty trick with a PHP loopback to save JS data on a file) |
GLMF#105 | 42-54 | |
| 2008.06 | "Introduction à la programmation graphique avec le framebuffer" | GLMF#106 | 66-76 | |
| 2008.07 | "Le CEA plébiscite les superclusters et l'Open Source" (one of the best articles I have ever written, according to some) |
LMHS#37 | 4-19 | |
| 2009.01 | "Programmation graphique : vers le framebuffer et au-delà !" | GLMF#112 | 82-? | |
| 2009.11 | "Un algorithme additif et itératif pour construire les Nombres Premiers" (Study of wheel algorithms to generate prime numbers) |
GLMF#121 | 65-75 | YES |
| 2010.04 | "Le VHDL pour ceux qui ont débuté" | GLMF#126 | 54-61... |
Yann Guidon / YGDES
fred frazelle
axf33480
llo
Merci beaucoup Yann! J'apprends le français à l'université, et je crois que ces articles m'aiderai utiliser des termes techniques en français...
