PCB for breakout boards and MEMS mic
05/05/2025 at 11:37 • 0 commentsnew PCB for breakout boards and MEMS mic
You’ll find in the project files the Gerber files for the PCB that holds the breakout boards.
It’s definitely better than a mess of Dupont wires with connections that get unreliable over time…A huge thanks to PCBWay for their service on this PCB !
This new PCB holds the decoupling capacitors, the MEMS mic, the breakout boards, and provides a connector for the parabolic mic assembly.
Gerbers and design files are now available in the files section.
Bertrand Selva
