First-gen, reCamera 2002 (w)
A project log for Customize Your Own AI Camera with reCamera Core
Combine 1 core board, 80+ sensors, and 4+ base boards—craft the unique reCamera with 80×4 or even 80×N possibilities with your creativity!
jennajenna 04/28/2025 at 06:490 Comments
First-gen reCamera
Core Board V1
So far, we have launched reCamera Core powered by RISC-V SOC SG2002. In addition to the onboard eMMC, there is also an onboard wireless solution ready for use. The wireless module, along with the onboard antenna, could provide you with basic Wi-Fi/BLE connection ability.
The difference between C1_2002W and C1_2002 is whether there is an onboard WIFI chip. They are from the same PCB design. The difference is that C1_2002 does not attach the Wi-Fi module.
Below are the introductions to these two core boards.
BoardFeaturesVersion
C1_2002w- eMMC
- WiFi/BLE module
- Onboard antenna
- External antenna connector
1.2
C1_2002- eMMC
- Extra SDIO to base board
- Extra UART to base board
1.2
The schematic is as below:
Sensor Board V1
The sensor board we have currently developed is the OV5647.
SensorOV5647CMOS Size1/4"
Pixels5MPApertureF2.8
Focal Length3.46mmField of View65°
Distortion< 1%Image2592 x 1944 (still picture)
Video1920 x 1080p @30fps, 1280 x 720p @60fps, 640 x 480p @60fps, 640 x 480p @90fps
Interfaces- 4 x LED fill lights
- 1 x microphone
- 1 x speaker
- 3 x LED indicator
Top ViewBottom View
UpBottom
Base Board V1
So far, we have developed two types of baseboards, B101_Default and B401_CAN. B401_CAN supports CAN communication and allows for the connection of more accessories, for example, you can connect a gimbal to achieve 360° yaw rotation full coverage and 180° pitch range from floor to ceiling.
B101_Default
Top ViewBottom View
UpBottom
B401_CAN
UpBottom
UpBottom
