LTE-modem-AT-command-tester
The LTE AT+ Command Tester is a Python-based tool designed to assist in the development of LTE-enabled products.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The LTE AT+ Command Tester is a Python-based tool designed to send, receive, and process AT+ commands for testing and configuring LTE modems. This project simplifies interaction with LTE modems by providing a script to automate command execution, parse responses, and log results. It is ideal for developers and engineers working on modem integration or network testing. Features Send AT+ commands to an LTE modem via a serial connection. Parse and display modem responses in a readable format. Support for common AT+ commands like AT+CREG?, AT+COPS?, and AT+CGDCONT. Configurable serial port settings (e.g., COM port, baud rate). Error handling for robust communication with the modem. Logging of command interactions for debugging and analysis.
