PI Pico 2 W USB TO LDAC Dongle
The Pico W USB Audio to Bluetooth Adapter transforms your Raspberry Pi Pico W into a high-quality LDAC audio streaming device.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Project website https://github.com/wasdwasd0105/PicoW-usb2bt-audio/tree/main-ldac Download Firmware: https://github.com/wasdwasd0105/PicoW-usb2bt-audio/releases/tag/V0.7 Driver-Free Setup Setting up PicoW requires no driver or software installation. Simply plug the Pico W into your device's USB port, set your Bluetooth headphones or speakers to pairing mode, and an automatic connection will be made. Multiple Bluetooth Codecs Pico W Bluetooth Adapter utilizes multiple codecs to deliver high-quality audio. LDAC The input is 16-bit 44100Hz PCM audio, and it can steam LDAC audio at 303(Mobile Quality) on Pico W and 606(Standard Quality) Kbps/ 909 Kbps on Pico 2 W.
