Specifications
- Model: GP-02
- Dimensions: 10.3 × 9.9 × 2.4 (±0.2) mm
- Operating Temperature: -40°C to 85°C
- Storage Environment: -40°C to 125°C, Humidity < 90% RH
- Power Supply Range: 2.7V ~ 3.6V
- UART Baud Rate: Supports up to 256,000 bps
- Certification: RoHS Compliant
- Supports BDS, GPS, GLONASS, GALILEO, QZSS, SBAS for combined and standalone positioning.
- Supports D-GNSS (Differential GNSS), A-GNSS (Assisted GNSS), ephemeris prediction, DR (Dead Reckoning) hybrid navigation.
- Maximum data update rate: 10Hz.
- 32-bit application processor with a maximum frequency of 133MHz, supporting dynamic frequency scaling.
- Supports PPS (Pulse Per Second) output.
- Peripheral Interface: UART.
Hardware Connection
Connect the development board to a computer using a USB to TTL serial adapter.
Power-on Test
After connecting the GP-02-Kit to the computer via the USB-to-TTL adapter, use the Ai-Thinker Serial Debugging Assistant to receive UART output information.
Default Baud Rate: 9600 bps
Output Information
$GNGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.5,4*04
$GPGSV,1,1,00,0*65
$BDGSV,1,1,00,0*74
$GNRMC,,V,,,,,,,,,,N,V*37
$GNVTG,,,,,,,,,N*2E
$GNZDA,,,,,,*56
$GPTXT,01,01,01,ANTENNA OPEN*25
NMEA Sentence Definitions:
Sentence | ID | Main Content |
GGA | 4E 00 | UTC time, latitude and longitude, fix quality, HDOP, altitude, number of satellites used. |
GLL | 4E 01 | Latitude and longitude, UTC time, fix status. |
GSA | 4E 02 | PRN numbers of satellites used, PDOP, HDOP, VDOP. |
GSV | 4E 03 | Visible satellites, PRN number, elevation, azimuth, carrier-to-noise ratio. |
RMC | 4E 04 | UTC time, latitude and longitude, status, speed, heading, date. |
VTG | 4E 05 | Speed and course over ground. |
ZDA | 4E 08 | UTC time and date. |
GST | 4E 07 | Pseudorange error RMS, position error in latitude, longitude, and altitude. |
Software Testing
- Download and run GnssToolKit3 software.
- Open the Serial Port menu from the main toolbar to configure UART settings.
Baud Rate Selection: Default is 9600 bps, adjust according to actual receiver settings.
NMEA View
Displays parsed NMEA sentence information in a structured format.
Carrier-to-Noise Ratio (C/N0) Bar Graph
Displays satellite signal strength in a bar graph; each bar represents a different satellite.
Sky Plot View
In the View menu, select Sky Plot to visualize satellite positions.
Note: Testing was conducted indoors, resulting in weaker satellite signals.
