Open Printer is an open-source, repairable inkjet printer designed to outlive your laptop, dodge planned obsolescence.
Black ink is great, but offering a printer with color options is even better!
Having the flexibility to use either one cartridge or both is a real advantage too.
The cartridge we used in the first proof of concept worked well for monochrome ink, but the three-color version (Cyan, Magenta, Yellow) proved difficult to reverse-engineer. On top of that, this cartridge model is fairly expensive and hard to find.
After seeing the incredible Magic Printer Cartridge Paintbrush project from SpritesMods (check it out here: https://spritesmods.com/?art=magicbrush), we decided to switch to a different cartridge reference.
This cartridge brings a lot of benefits: higher print resolution, a more compact design, fewer signal contacts, easier sourcing (a lot in garbage bin) and it’s cheaper. What more could you ask for?
Here’s how we worked through this transition step by step.
Next log, next step !
one small question.
how print one pixel on paper? Any idea PCL? direct instructions?
Merci ! C'est la première version, je vais bientôt poster les nouvelles :)
Très belle réalisation ! La partie mécanique est vraiment super propre....
If you want to have some news check out our CrowdSupply campaign : https://www.crowdsupply.com/open-tools/open-printer/
