Introduction
The DRV8243 is a highly integrated brushed DC motor driver IC from Texas Instruments, designed to deliver efficient, reliable, and compact motor control for a wide range of industrial, automotive, and embedded applications. This project focuses on developing a motor driver board using the DRV8243P or DRV8243S variant, capable of driving a single brushed DC motor with a supply voltage range of 4.5V to 36V and a peak output current up to 6A.
For Full Project:
https://electronicsworkshops.com/2025/02/19/motor-driver-board-using-drv8243/
Bill Of Materials
| Component | Description |
| DRV8243P or S | Motor driver IC |
| TVS Diode (SMAJ36A) | For surge protection |
| 100nF + 10µF caps | For VIN bypass |
| 470µF cap | Bulk capacitor near VIN |
| Resistors | Pull-up (e.g., 10k for nFAULT, MODE) |
| Microcontroller | Optional, for logic control (e.g., Arduino) |
| Screw terminals | For motor and power |
DRV8243
The DRV8243 is a motor driver IC from Texas Instruments, designed for driving brushed DC motors and solenoids. It is part of the DRV824x family, which offers integrated features to control motors efficiently in automotive, industrial, and other embedded applications.
Key Features of DRV8243:
- Motor Type: Brushed DC motors
- Voltage Range: Operates typically in the 4.5V to 36V range
- Output Current: Supports up to 6 A peak current
- Control Interface:
- Can be configured for PWM (Pulse Width Modulation) control
- PH/EN or IN/IN interface options
- Protection Features:
- Over-current protection (OCP)
- Over-temperature protection (OTP)
- Under-voltage lockout (UVLO)
- Load-dump protection (automotive transients)
- Diagnostic Feedback: Fault indication for system-level feedback
- Low Standby Current: Efficient for battery-powered systems
- Package: Typically offered in compact HTSSOP or QFN packages
For Full Project:
Block Diagram
Power Input:
- VIN: 12V to 36V input
- GND: Common ground
- Capacitors:
- 100nF + 10µF (ceramic) near VIN pin
- 470µF electrolytic near input connector
DRV8243 Pins:
- IN1 / IN2 or PH / EN: Motor control (from MCU or logic pins)
- nSLEEP: Tie HIGH for operation or control via MCU
- nFAULT: Open-drain fault output (connect to MCU or LED)
- MODE: Tie LOW for IN/IN or HIGH for PH/EN
- IPROPI: Optional current sense output
- OUT1/OUT2: Connect to motor terminals
Schematic Diagram
This motor driver circuit uses the Texas Instruments DRV8243 IC to control a brushed DC motor efficiently, with integrated protection and diagnostic features. The input power (12–36V DC) is filtered and protected using a TVS diode, bulk and bypass capacitors, and a AGM40P75 N-channel MOSFET configured for reverse polarity protection. The DRV8243 receives filtered power and drives the motor via its OUT1 and OUT2 pins, while control signals (PH/EN or IN1/IN2) from a microcontroller define motor direction and speed. Pull-up resistors are used for logic pins like MODE, nSLEEP, and nFAULT, while capacitors near VIN ensure stable operation. Optional current sensing is enabled via the IPROPI pin with a resistor to ground, and nFAULT can be monitored via an MCU or LED. The result is a compact, reliable, and robust motor driver board suitable for industrial, automotive, or robotics applications
PCB Files
3D files
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
Order Now……
Applications:
- Automotive seat and window actuators
- Power tools
- Robotics
- Factory automation
- Electric valves or pumps
Conclusion
This DRV8243-based motor driver board provides a compact,...
Jithin Sanal
ridonkulus
