The modules created for the project consist of:
- Voltage Controlled Oscillator x2 (utilized the SSI2131 IC)
- 4 Channel Mixer (op-amp summing circuit with LPF)
- Voltage controlled filter (low-pass) - diode ladder based design
- Voltage controlled amplifier - long tailed differential amplifier based design
- Envelope Generator - 555 timer in monostable output configuration
- Low frequency oscillator - relaxation oscillator based design
- Delay effect module - uses the PT2399 delay IC
- Waveform Display (OLED) - Arduinonano based
- Stereo output - Class A amplifier with additional panning controls
