I've been annoyed for a while with the alignment of boards when milling double sided PCBs. So, I've decided to make a customized version of a PCB mill which makes this so much easier. And while doing that, why not create the whole "3D Printer" experience?
Basically, I want to insert a USB stick and press Play. And only have to do something, when I have to flip the board (unless I figure something out).
The minimum features are:
- 200x300 mm2 work area (been running out of space on my current CNC3018)
- Optical alignment of the board for making double sided boards
- Automatic Tool Changer (ATC) for the ER11 collet
- Support GERBER (KiCad output) as input format
- Automatic Toolpath Generation - or a plugin for KiCad
- Software runs on Raspberry Pi with a touch screen
Nice to have features:
- Automatic Board flip function
