BU03-Kit Development Board (Hardware Section 2)
——AndyL
3. Functional Effectiveness Testing
1. Quick Start Test
UART 1
1. Connect a Type-C data cable to your PC, open a serial terminal tool, and press the reset button. If the terminal prints the expected boot messages, the reset button works properly.
- Send the command AT; if you receive OK, the send/receive test passes.
USB
The USB port is the TypeC connector labeled USB on the BU03Kit, used for printing distance measurements and other info. It uses the STM MCU’s builtin USB driver. Windows and macOS usually won’t auto-install this driver, so you must manually install it.
UART2
Testing UART2 requires a USBtoTTL adapter. UART2 will output ranging data (covered in later sections).
Wiring for USB to TTL adapter:
BU03Kit Pin | Adapter Pin |
3V3 | 3V3 |
GND | GND |
PA2 (TX) | RX |
PA3 (RX) | TX |
LED Flow Test
Connect to the TTL port and send:
AT+TESTLED=X
Parameter | Description |
X = 1 | Start LED flow test |
X = 0 | Stop LED flow test |
Response:
- OK — AT command succeeded
- ERR — AT command failed
- Send: AT+TESTLED=1
- Receive: OK
- Configure one BU03Kit as anchor, another as tag.
- Anchor’s OLED or USB port will display the current distance to the tag.
- Keep antennas unobstructed and tags off flat surfaces to minimize error.
- For higher precision, use the calibration command (below).
Example:
2. UWB Function Tests
Distance Only (Zeropoint) & 1D Positioning
With one anchor and multiple tags, you get realtime distance measurements (no direction). Adding a second anchor lets you compute onedimensional positions along a line.
2D Positioning (3 Anchors)
Three anchors plus tags yield basic 2D positioning. If one anchor is blocked or interfered, loss of redundancy hurts accuracy. Ensure clear lineofsight between anchors and tags.
You only need any one module (anchor or tag) to stream positioning data via USB/UART/WiFi/Ethernet to a PC; other anchors just need power and will forward data wirelessly.
Improved 2D (4 Anchors)
Four anchors add redundancy: if one is blocked, the extra data preserves accuracy. Same lineofsight requirement and streaming setup applies.
3D Positioning (6+ Anchors)
Six or more anchors support largearea 2D or full 3D positioning, with robust redundancy under blockage. Same streaming and power requirements.
Common AT Commands
Command | Description | Response | Example |
AT+SETUWBMODE=X | Select algorithm (must save after): 0 = TWR, 1 = PDOA | OK/ERR | Send AT+SETUWBMODE=0 → OK |
AT+GETUWBMODE | Query current algorithm | OK/ERR | Send AT+GETUWBMODE → twr_pdoa_mode: 0 OK |
AT+SAVE | Save current configuration | OK/ERR | Send AT+SAVE → OK |
AT+SETCFG=X1,X2,X3,1 | Set config (then save):- X1 = Device ID (0–10)- X2 = Role (0=Tag, 1=Anchor)- X3 = Channel (0=ch9, 1=ch5)- Rate fixed at 6.8 Mbps | OK/ERR | Send AT+SETCFG=0,1,0,1 → setcfg ID:0, Role:1, CH:0, Rate:1 OK |
AT+RESTORE | Restore factory defaults | OK/ERR | Send AT+RESTORE → OK |
TWR Algorithm: Ranging & Positioning
Setup
Ranging Steps
- On Anchor (A):
- On Tag (B):
AT+SETUWBMODE=0
AT+SETCFG=0,1,1,1
AT+SAVE
AT+SETUWBMODE=0
AT+SETCFG=0,0,1,1
AT+SAVE
Anchor’s OLED shows distance to Tag.
Observed without calibration: ±20 cm fluctuation.
2D Positioning
- Use three anchors and one tag.
- After configuring all, open the TWR PC software, connect any anchor via USB, and view realtime 20 m range navigation and track display.
- If USB isn’t recognized, restart software or replug the cable.
- Place anchors ≥1.5 m high with clear lineofsight (tripods recommended).
PDOA Algorithm: Ranging & Angle
Method A: PC Software (non-persistent)
1. Configure Anchor (A) and Tag (B):
AT+SETUWBMODE=1
AT+SETCFG=0,1,1,1
AT+SAVE
AT+SETUWBMODE=1
AT+SETCFG=0,0,1,1
AT+SAVE
- Open PDOA PC software: add the tag, then move it—software shows angle A and distance D in real time. Anchor OLED shows the same.
Method B: ATbased Binding (persistent)
1. Same config as above.
- Watch the anchor’s TTL output for the Tag ID, then bind it:
- Anchor OLED shows distance D and angle A (range: –60° to 60°).
AT+ADDTAG=267F1313,8834,1,64,0
AT+SAVE
Mobile Device Tracking (e.g., AirTag)
By combining BU03 UWB, Nordic nRF52832 BLE, and PDOA, the kit can interact with UWBequipped smartphones.
Brand | Models with UWB Chip |
Apple | iPhone 11 and later (current: iPhone 16) |
Samsung | Galaxy S22+ series and above (Ultra/+ models); Fold W23–W25, Z Fold6 (highend only) |
Pixel 6 Pro and later (Pro only; current: Pixel 9 Pro) | |
Huawei | Mate XT Master, Mate 70 RS Master (2024); Mate 60 Pro (2023) |
Xiaomi | Mi Mix 4 (2021) only |
Meizu | 20 Pro, 20 INFINITY |
NIO | NIO Phone (all 3 versions) |
Manual / Development SDK
Power Consumption Test
Under factory firmware (TWR mode):
- Tag: 318.2 mW
- Anchor: 487.3 mW
- Using one anchor and one tag with default firmware is very straightforward. After calibration, distance and angle measurements become accurate.
- Reading quicklychanging OLED data can be tricky; using the PC software is easier.
4. Distance-Precision Calibration & Serial Data Formats
TWR UART Data Parsing (USB)
Field | Size | Description |
head | 6 B | Fixed "CmdM:4" |
len | 1 B | Length of <timer-Pos_TagZ> |
Timer | 4 B | Tag timestamp |
Tagid | 2 B | Tag address |
Ancid | 2 B | Anchor address |
Seq | 1 B | Sequence number |
Mask | 1 B | Validbits mask |
Rawrange0–7 | 32 B | Raw distance data for tags 0–7 |
Kalman_enable | 1 B | Filter on/off flag |
Kalman0–7 | 32 B | Filtered distances for tags 0–7 |
Pos_enable | 1 B | Hardware positioning on/off (costly) |
Pos_dimen | 1 B | Dimension: 1=2D, 2=3D |
Pos_Ancmask | 1 B | Active anchors mask |
Pos_Tag_Res | 1 B | Position result flag |
Pos_TagX/Y/Z | 4 B each | Position coordinates (x,y,z) |
Check | 1 B | XOR checksum |
Foot | 1 B | Fixed \r\n |
TWR UART2 Frame
Field | Size | Notes |
Head | 1 B | 0xAA |
Len | 1 B | From version to tail |
Version | 1 B | Protocol version |
Data | 32 B | Filtered distances for anchors 0–7 |
Checksum | 1 B | Sum from Head → end mod 256 |
Tail | 1 B | 0x55 |
PDOA Serial Formats
JSON Mode
JS006C{"TWR":{
"a16":"4096",
"R":115,
"T":0,
"D":76,
"P":-123,
"Xcm":-57,
"Ycm":50,
"O":408,
"V":49152,
"X":0,
"Y":0,
"Z":0
Key fields: Xcm, Ycm → angle = arctan(Xcm/Ycm) × 180/π ≈ 23.62°
Addr | 2 B | Tag address |
Angle | 4 B | Angle |
Distance | 4 B | Distance |
usercmd | 2 B | Custom flags (battery, alarm) |
F_Path_Power_Level | 4 B | Firstpath signal strength |
RX_Level | 4 B | Received signal strength |
Acc_X/Y/Z | 2 B×3 | Accelerometer (x,y,z) |
Foot | 1 B | 0x23 |
Example: Distance 0x38 → 56 cm; Angle 0xEFFFFFFF → –17°.
Calibration Procedure
- Download the autocalculation Excel template.
- Place the tag at measured 1 m intervals, record actual vs. displayed distances in the spreadsheet; it outputs a linear coefficient, e.g.: y = 0.9924x – 317.68.
- Send calibration command (retain other params):
AT+SETDEV=10,16336,1,0.018,0.642,0.9924,-317.68,0,0
AT+SAVE
5. User Experience & Optimizations
Recommended Improvements:
- Replace BU03-Kit MCU with lowpower STM32C/L series or an ESP32C/S (WiFi/BT) or NRF52832 (BLE) for greater flexibility.
- Reduce unused onboard LEDs to save power; add a Libattery interface for portable, lowpower deployments.
Ai-Thinker
