DWG Drawing - 23.98 kB - 02/01/2018 at 15:25 |
DashDisplayR3.zipArduino sketch running an LCD display on the dash. This recieves data via UART and also feeds data out of the usb serial port for logging. Also displays text and audiable alarms.x-zip-compressed - 2.04 kB - 11/20/2017 at 22:05 |
PiggyBackSoftwareR07.zipCurrent software running on the piggy back controller. Runs the engine well at around 450 mBar of boost. Runs on Infinion Davex-zip-compressed - 7.06 MB - 11/20/2017 at 22:02 |
PiggybackDesignR01.pdfCurrent piggy back design. Running well in the car.Adobe Portable Document Format - 62.83 kB - 11/20/2017 at 21:59 |
Part005R1 Turbo Exhaust outlet.dwgPart checked to fitDWG Drawing - 131.26 kB - 04/05/2017 at 10:23 |
Part004R1 Throttle Body Flange.dwgnot used but did fitDWG Drawing - 138.54 kB - 04/05/2017 at 10:23 |
Part003R1 Turbo Exhaust Inlet.dwgPart checked to fitDWG Drawing - 131.60 kB - 04/05/2017 at 10:23 |
Part002R1 Rear Exhaust Ssystem Flange.dwgDID NOT FIT. Holes on the corners are in the wrong position. Not updated to fitDWG Drawing - 131.54 kB - 04/05/2017 at 10:23 |
Part001R2 Engine Exhaust Flange.dwgParts checked to fitDWG Drawing - 144.95 kB - 04/05/2017 at 10:23 |
