This study explores a novel method of environmental sonification using temperature data collected from a USB thermometer. By converting these values directly to audio samples and playing them back at 8 kHz, subtle patterns emerged in the data—some of which closely resemble speech-like formants.
Upon further analysis and cross-referencing with solar and geomagnetic activity logs, a consistent correlation between structured audio phenomena and known space weather events was discovered. The study suggests that this setup may be passively sensitive to low-frequency electromagnetic field variations, effectively turning the thermometer into an unintended EMF detector. This document outlines the methodology, validation against independently generated audio, and proposes future work in signal analysis, instrumentation, and citizen science.
