A Tiny Photo Frame From an ESP8266 Smart Clock
If your pet needs a cute little TV, I happen to have one. You can make it for under $7. This is my entry to the 2025 Pet Hacks Challenge.
1.3k views
0 followers
This tiny gadget is sold as the "Smart Clock" or "GeekMagic Smart Weather Clock." It's a cute little IoT widget, but the proprietary software is definitely a deal-breaker. No one wants to tolerate an unknown piece of code in their wireless network. Or could we liberate it and make the "Smart Clock" even smarter? Let's find out!
Demo video
  • 1 × ESP8266 "Smart Clock" Apparently, there are two versions. The "Pro" version is reported to have a touch button and is powered by ESP32. The cheaper one I used in this project is powered by ESP8266. They can be purchased in different colors.
  • The Project Story
    arduinocelentano05/10/2025 at 15:38 0 comments
    ✎ So this strange gadget just popped up among other annoying things you didn't ask for. I skimmed through the reviews customers attached and on one of the pictures saw some piece of electronics that looked like one of ESP8266 modules. So for less than 7USD you get a supposedly programmable MCU board with a nice IPS display and a neat tiny enclosure. Let's give it a try!
    ✎ Few weeks later. The good news is that the board has an embedded USB-TTL chip, wow! I only need a Type-C cable to upload the firmware. It works! All except the display. I sort of bricked it, so now it's a useless ESP8266 board with an unknown display that has an unknown pinout and needs an unknown driver.
    ✎ Few hours later. I tried to track the display connection with a multimeter. Not as easy as it sounds due to tiny pads size, but manageable. However it tells nothing about the display type, and the role of some pins is still unclear. By the way, I managed to unbrick it by uploading the official firmware. Unfortunately, only binaries are available, so it's more or less useless. Who wants an unknown binary code being executed in their home network? But maybe I could disassemble it and find out missing details?
    ✎ Few hours later. Forget disassembling! Now I'm nearly sure the display is some sort of ST7789. I found some pictures of similar displays and two possible pinouts. Tried to run standard Arduino examples for ST7789, but no success. Some details are still missing. Maybe I'll need to make a breakout adapter to connect the display to another ESP8266 board to test it separately. The good news is that the stock firmware still works, so I did not destroy the display.
    ✎ Apparently someone did the rest of the job for me. Michał Kalbarczyk teared down a similar gadget, probably another version of this device. But the connection was the same. Now I finally could control the display with Adafruit ST7735 and ST7789 Library!
    ✎ To this point I was not sure what I wanted to build with this hardware. I considered porting my recent ESP82866 project, but quickly realized that the TFT display could not be updated as quickly as monochrome OLED with this type of microcontroller.
    ✎ What about a tiny cute photo frame? The display seems to be suitable for it. I tried using PROGMEM to store images, and it worked pretty well. I discovered the lcd-image-converter, a tool for converting images into PROGMEM arrays. According to people who used it, it appeared to work fine, but... installing Qt seemed to be an overkill for such a simple task and using GUI to manually convert each image was not my cup of tea, so...
    ✎ I used ffmepeg and imagemagick to convert my images to RGB565 bmp, which is suitable for Adafruit_ST7789. Both of them worked, but ffmpeg generated better results. Maybe some imagemagick command line flags tuning could fix it. BMP headers are easy to process, so I wrote a simple Python script that simply skipped them and extracted raw BMP data in PROGMEM format. Now I can build an automated workflow for converting images, but...
    ✎ The bad news is the size of BMP data. With 240×240 resolution and two bytes per pixel you have 115200 byte images. With 1Mb sketch partition the photo frame is limited to 5-6 pictures, because the code lives in the same partition.
    ✎ I looked for similar solutions and found another ESP8266 photo frame by tonyliuguo. It used similar approach with PROGMEM but with a smaller display. Nothing new.
    ✎ Suppose I'll move my images to SPIFFS. With 4Mb flash, and therefore max 3Mb SPIFFS partition, it gives me a space for about 20+ photos, which is slightly better. It works! And it's painfully slow.
    ✎ I've just discovered TFT_eSPI library. It works somewhat faster than Adafruit_ST7789. Have to rewrite my display driving code.
    ✎ Finally it works more or less flawlessly. But maybe I could implement some sort of image compressing? Would this...
View project log
  • 1
    Preparing the Environment
    Go to https://platformio.org/platformio-ide and follow the installation instructions.
    In PlatformIO IDE click "Clone GIT repository" and paste the following URL:
    https://github.com/arduinocelentano/smartclock-photoframe
    PlatformIO should automatically download the project and the libraries it depends on.
  • 2
    Preparing Your Photos
    You should convert your photos to JPEG and resize them to 240×240. They should be called 1.jpg, 2.jpg, 3.jpg, etc.
    To do this automatically, you can use the following Bash + Imagemagick script. You can change the JPEG_QUALITY constant to accommodate more photos.
    #!/bin/bash
    # Set the target size
    TARGET_SIZE=240
    # Set the JPEG quality (1-100)
    JPEG_QUALITY=85 # You can change this value as needed
    # Initialize a counter for renaming
    counter=1
    # Loop through all image files in the current directory
    for file in *.{jpg,jpeg,png,gif,bmp}; do
    # Create the new filename
    new_filename="${counter}.jpg"
    # Use ImageMagick to resize and crop the image
    convert "$file" -resize "${TARGET_SIZE}x${TARGET_SIZE}^" -gravity center -crop "${TARGET_SIZE}x${TARGET_SIZE}+0+0" +repage -quality "$JPEG_QUALITY" "$new_filename"
    echo "Saved: $new_filename with quality $JPEG_QUALITY"
    # Increment the counter
    ((counter++))
    done
    echo "Image processing complete."
    Copy the images to the project's data directory and set the IMAGES_COUNT constant in main.cpp. For example, if you have 150 images, it will look like this:
    #define IMAGES_COUNT 150
  • 3
    Uploading the Photos
    The pictures are stored in a separate flash partition. Select Build Filesystem Image and Upload Filesystem Image in the PlatformIO tab. This process will take some time, depending on the size of your files.
    ⚠️ I used the eagle.flash.4m3m.ld build script, which leaves approximately 3048 KB for SPIFFS. If you could not complete this step, your filesystem image might be too large.
View all 4 instructions
