Pixel 3 XL NetHunter C-deck
Pixel 3 XL NetHunter Clamshell Palmtop
A DIY portable cyberdeck built from a Google Pixel 3 XL running Kali NetHunter, paired with a Bluetooth keyboard and enclosed in a custom 3D-printed clamshell case. This compact setup provides a highly portable, low-cost platform for penetration testing and network analysis. The clamshell form factor enables comfortable typing and efficient mobile workflow, turning a smartphone into a practical pocket-sized command terminal for on-the-go technical tasks.
The Idea
This project converts a Google Pixel 3 XL smartphone into a clamshell-style palmtop, paired with a Bluetooth keyboard and enclosed in a custom 3D-printed case. The result is a compact, low-cost portable device ideal for field work, diagnostics, and general-purpose computing.
I’ve always been a fan of clamshell palmtops — a fascination that started years ago when I worked as a network field engineer. Back then, I used a NEC MobilePro 900 to configure and troubleshoot network equipment on-site. I really liked how practical and easy to use that form factor was.
Though the Pixel 3 XL is an older smartphone, it’s still a capable piece of hardware. By repurposing it and combining it with a folding Bluetooth keyboard, this project gives it a second life as a functional palmtop — one that’s easy to carry and quick to deploy.
The current version of the case securely holds both the phone and keyboard in a folding layout. I'm working on refining the 3D-printed design to make it easier to print, assemble, and customize for others who share a love for classic computing form factors.
Version 1.0.0
The first version of this device was created with a rugged design in mind. It appears that this design could lead to a more sophisticated assembly. While it is nice to be able to make the device in two colors with a pretty attractive appearance, a less complex assembly will be prioritized in the next version.
Version 2.0.1
The second version of this device has fewer 3D-printed parts and are much easier to assemble. I've tried to preserve the device’s attractive appearance, even with fewer options for using different filament colors.
Both models have a panel on the back of the lid that can be used to mount external wireless modules connected via an OTG cable. I reused a panel I had originally designed for organizing cables in my work bag, but never ended up using
The panel's shape and design make it ideal for strapping external cards.
Version 2.1.0
This is the latest, and probably the final, version of this case. I’ve moved the phone to the center of the lid, removed the parts of the case that were meant for securing cables and external cards with plastic ties, and modified the upper panel design
Version 2.2.0 - PETG
This is the updated device's design to make it more suitable for printing with PETG filament. It also has the better lock slider design to fix the issue of sliders falling out while the device is open.
Download links
All versions' 3D models can be downloaded by the links below.
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v1.0.0
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.0.1
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.1.0
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.2.0 PETG
  • 1 × Google Pixel 3XL https://www.ebay.com/sch/i.html?_nkw=Google+Pixel+3+Xl
  • 1 × Universal Bluetooth Keyboard https://www.amazon.com/Doohoeek-Universal-Bluetooth-Any-Angle-Kickstand/dp/B0CP9KC535/
  • 1 × USB C OTG with Charging https://www.amazon.com/dp/B0B5MPCJF5/
  • 3 × Hook and Loop Cable Tie https://www.amazon.com/Black-Reusable-Cable-Guitar-Speaker/dp/B07PRZL7LD
  • 2 × M3x12 screw
  • Completed printing and assembly for v2.2.0
    Sergiy06/21/2025 at 13:07 0 comments
    I've printed and assembled version 2.2.0 of the case using PETG. It can't be captured in a photo, but the device feels much nicer to the touch, and the resulting print is significantly more dimensionally accurate.
  • Design update v2.2.0 - PETG
    Sergiy06/15/2025 at 15:31 0 comments
    I've updated the device design to make it more suitable for printing with PETG filament. In short, I made all parts of the case thicker to improve its sturdiness. I've also updated the lock slider design to fix the issue of sliders falling out while the device is open.
  • Completed printing and assembly for v2.1.0
    Sergiy06/05/2025 at 19:11 0 comments
    I've printed and assembled version 2.1.0 of the case. It needs Velcro ties at least 200 mm long now. I really like how it looks.
  • Design update v2.1.0
    Sergiy06/04/2025 at 08:29 0 comments
    After a few days of testing, I decided the OTG cable doesn’t need to stay connected all the time, so there’s no reason to hide its connector deep in the case. I also dropped the idea of using cable ties, which made the circular holes (and really the whole original panel design) unnecessary. Built a new  version of the case.
  • Completed printing and assembly of Version 2
    Sergiy05/24/2025 at 17:37 0 comments
    Just finished printing and putting together Model V2. It turned out a bit more work than expected. I had to do quite a bit of sanding and filing to get the parts to fit right. I tweaked the design and made a 2.0.1 version to fix the worst of it, but it still needs some cleanup after printing.
  • The second version of the design is completed
    Sergiy05/22/2025 at 08:06 0 comments
    The new case has fewer parts to print and should be much simpler to assemble. Two main changes made this possible: the protective bumpers on the corners were replaced with a thicker layer of plastic, and the hinges were completely redesigned to be printed together with the case parts.
  • NetHunter Installation Instruction
    Sergiy05/21/2025 at 15:45 0 comments
    I've added detailed instructions on how to convert a Google Pixel 3XL smartphone into a network diagnostic and penetration testing device.
  • Device Redesign – Phase 1
    Sergiy05/21/2025 at 14:25 0 comments
    I started working on the second version of the device.
View all 8 project logs
  • 1
    Prerequisites
    Flash Stock Android 12
    Enable Developer Mode & USB Debugging
    • Go to Settings > About phone
    • Tap Build number 7 times to enable Developer Mode
    • Go to Settings > System > Developer options
    • Enable OEM unlocking and USB debugging
    Unlock the Bootloader
    • Confirm the prompt to unlock the bootloader
  • 2
    Download Required Files
    Download the following files to your PC:
  • 3
    Installation
     Reboot into Bootloader
    adb reboot bootloader
    Boot TWRP Recovery
    fastboot boot twrp-3.7.0_12-0-crosshatch.img
    Push Installation Files to the Device
    adb push twrp-installer-3.7.0_12-0-crosshatch.zip /sdcard
    adb push magisk28.1.zip /sdcard
    adb push Alynx-12-nethunter-bluecross.zip /sdcard
    adb push Wireless_firmware.zip /sdcard
    Install Files via TWRP (in this order)
    • twrp-installer-3.7.0_12-0-crosshatch.zip
    • magisk28.1.zip
    • Alynx-12-nethunter-bluecross.zip
    • Wireless_firmware.zip
    Use TWRP > Install for each zip file.
    Reboot to System
    Once installation is complete, go back to TWRP > Reboot > System
    Set Up Magisk
    • Open the Magisk app
    • Follow on-screen instructions to finish setup
    • Reboot the phone if prompted
    Install Kali NetHunter Module
    • Copy the NetHunter archive to your device using file transfer.
    • Open Magisk > Modules
    • Tap Install from Storage and select the NetHunter zip archive
    • Reboot after installation
View all 3 instructions
Christopher Gilbert wrote 07/05/2025 at 12:42 point
I'm interested in remixing this to fit my device (Pixel 9 Pro Fold). Is there a possibility that the CAD could be released.  Or perhaps just the upper portion so that we can customize it to our needs?  Thanks for the awesome design!
Sergiy wrote 07/05/2025 at 17:09 point
At the moment, I'm working on a modular design that allows the mobile phone case to be printed as a separate part. The idea is to make it snap securely into the main body of the case, which should simplify printing and improve overall fit and customization. You can take a look on my very first model which has something similar.  https://www.printables.com/model/1230947-3d-printed-case-for-wireless-keyboard-and-xiaomi-p
Christopher Gilbert wrote 07/05/2025 at 19:04 point
Thanks for the quick reply!  Looking forward to the update. In the meantime, if you're looking for help I have CAD/3D printing experience and would be happy to help.
Sergiy wrote 07/05/2025 at 19:26 point
I enjoy 3D modeling. It's my favorite hobby, so I’m happy to handle it myself for now. Anyway, thanks for the offer, I really appreciate it!
bryantm wrote 07/04/2025 at 07:33 point
I printed version 2.01 and the keyboard print failed. Do you have any plans to add other versions of this case?
Sergiy wrote 07/04/2025 at 09:33 point
The current version is v2.2.0, which is more suitable for PETG, but there should be no problem printing it with PLA. I assume you're having a printing issue with the hinge part of the case. I had the same problem, so I spent some time investigating the proper slicer configuration and reconfigured it to get the best results from my 3D printer — a fairly cheap Chinese printer branded Flyingbear GHOST 6.
bryantm wrote 07/04/2025 at 09:40 point
Sorry I didn't make myself clear. The keyboard printed fine. The case broke when I put the keyboard into the case. The thinner part of the keyboard case broke away from the rest of the keyboard case.
Sergiy wrote 07/04/2025 at 09:55 point
I had similar issue too.  I had layers adhesion problem after replacing brass nozzle with hardened steel one. I've fixed it by adding 20 degrees to my current hotend temperature..
Sergiy wrote 07/04/2025 at 10:06 point
But anyway, v2.2.0 has all parts of the case much thicker comparing to all previous versions.
0xh4z wrote 07/01/2025 at 03:35 point
Thanks for the inspiration! Now I know what I can do with my old phones!
Harlw wrote 06/27/2025 at 14:52 point
Love it! What did you design it in? I'd be interested in creating revisions for additional phones.
Kai Morgan wrote 05/24/2025 at 15:19 point
Would  love to see this as a modular case to change devices as I have the OnePlus 8Pro with a full Nethunter install. This is beautiful work!
Adam wrote 05/23/2025 at 03:44 point
What are the contents of the Magisk zip?  Is it just the source zipped up?
Sergiy wrote 05/23/2025 at 05:32 point
Yes.  You just need to change .apk to .zip and write it. Forgot to mention it. I will update the manual.
Fabricio Robles wrote 05/22/2025 at 07:54 point
I love this! That is hell of an asset to have. Now I am wondering if my Oneplus 8T would be a good candidate for a similar project.
Mike wrote 05/21/2025 at 16:53 point
I love the idea!  There's so much that can be done with a palmtop in that form factor.  Now you've got me thinking of what hardware I've got laying around that could be used for a similar purpose.  Maybe it's time to build my own.  Thanks for sharing!
Sergiy wrote 05/21/2025 at 17:13 point
I'm really glad to hear my project inspired you! You're very welcome!
X1tedless wrote 05/21/2025 at 16:26 point
what a great project, keep it up
Josh wrote 05/21/2025 at 16:23 point
Just came to say this looks awesome! I love the clamshell style too, just looks so cool as well as being useful.
Out of interest, what's the external aerial and circuit board shown in the pictures, it's not in the list of parts?
Sergiy wrote 05/21/2025 at 16:39 point
This is "naked" TP-LINK TL-WN722N wireless card which is pretty common device for testing 2.4 WiFi network. I've added a custom minimal casing 3d model for it in the files.  I used it to depict the use of the panel on the back side.
