The second version of the design is completed
A project log for Pixel 3 XL NetHunter C-deck
Pixel 3 XL NetHunter Clamshell Palmtop
sergiySergiy 05/22/2025 at 08:060 Comments
The new case has fewer parts to print and should be much simpler to assemble. Two main changes made this possible: the protective bumpers on the corners were replaced with a thicker layer of plastic, and the hinges were completely redesigned to be printed together with the case parts.
