Here you can see the menu selection for the tACS continuous mode. In this sub-menu, you can choose the frequency, which is controlled with a potentiometer. The range frequency is from 1-100Hz, defined in the program code. Also, you can choose the desired current intensity (setpoint), it is defined from 0.5mA to 3.0mA, a safe range for TES. More explanation in other updates.
