PicoRAM Ultimate
SRAM Emulator and SD Card Interface for Vintage Single Board Computers (such as the Heathkit ET-3400, Lab-Volt 6502, and Microprofessor)
PicoRAM Ultimate is the ultimate storage solution for single board computers (SBCs) / CPU trainers from the 70s and 80s. It emulates: - up to 4 2112 SRAM chips: it replaces the 512 bytes of stock SRAM in the Heathkit ET-3400; alternatively, - a 2 KB memory expansion for the Heathkit ET-3400 (with expansion header installed), - a single 6116 2 KB SRAM (e.g., for the Multitech Microprofessor MPF-1 / 1B / 1P), - up to 4 2114 SRAM chips (e.g., for the Lab-Volt 6502 and Philips MasterLab MC6400 CPU trainers, or the the 2 2114 SRAM chips in the Heathkit ET-3400A). Using the built-in SD card interface, PicoRAM Ultimate allows you to save and load full memory dumps (including programs and data) to and from SD card, hence, rendering the cassette interfaces of these SBCs obsolete (if they even came with one; i.e., the ET-3400 required an extra memory expansion + IO box for the cassette interface, and the Lab-Volt 6502 does not come with one either).
picoram-ultimate
A Raspberry Pi Pico (RP2040)-based SRAM Emulator and SD Card Interface for vintage Single Board Computers (SBCs).
About
PicoRAM Ultimate replaces some (or all) of the RAM chips of these systems by emulating them in software with a Raspberry Pi Pico (RP2040) microcontroller, slightly overclocked at 250 MHz. PicoRAM is equipped with an SD card to store and load whole memory dumps to and from SD card. These memory dump .RAM files are similar to Intel HEX ASCII format and can be edited easily by hand on the PC. The utilized FAT file system facilitates data / file exchange with the PC or Mac.
PicoRAM Heathkit
Currently supported SBCs / host machines are:
  • Stock Heathkit ET-3400: MC6800 CPU, either 2x 2112 (512 Bytes) or 4x 2112 (1 KB)
  • Stock Heathkit ET-3400A: MC6808 CPU, 2x 2114 (512 Bytes only!)
  • Heathkit ET-3400 memory expansion mode: MC6800 CPU, 2 KBs via expansion header and additional GAL16V8 address decoder
  • Multitech Microprofessor MPF-1, MPF-1B and MPF-1P: Z80 CPU, 1x 6116, 2 KBs
  • Lab-Volt 6502: 6502 CPU, 2x 2114, 1 KB
  • Philips MC6400 MasterLab: INS8070 SC/MP III CPU, 2x 2114, 1 KB
The development logs are on Hackaday.
This project is a follow-up to PicoRAM 2090 for the Busch Microtronic Computer System and PicoRAM 6116 for the Microprofessor MPF-1.
Video
This YouTube video shows most currently suported machines (with the exception of the MPF-1P):
YouTube Video
Latest News
January 2026
The stock Heathkit ET-3400A is supported by now - firmware version 1.6 has been uploaded.
ET-3400A a)
Here is a YT video.
October 2025
During my RetroChallenge 2025/10 contribution, I encountered a pretty nasty issue which took me quite a while to debug and resolve. Mostly chasing red herrings.
My rotating 3D Cube was glitching, and it took me a long time to realize that this was caused by noisy ADC button decoding and inappropriate ADC level thresholds. The problem was that this happened without visual feedback in the UI, so I was unware of it. Now, for each detected button press, the SRAM emulation is halted; and also for spurious button presses that don't cause an UI action (the CANCEL2 button was responsible). Now, halting the SRAM emulation can only work properly if the Z80 WAIT signal is connected to PicoRAM, which I had not in this case. Sometimes, I simply hold the RESET button manually on the Microprofessor instead whilst operating PicoRAM. Obviously, you can't just halt SRAM emulation and not halt the CPU and expect it to run properly.
So, this problem was fixed by adjusting the ADC threshold levels in the ULTIMATE.INI file. However, I didn't like that the spurious button presses weren't reported and happened "silently", leaving me unaware of what was happening. In the UI loop code, there was no switch case that caught this case, and a default clause was missing as well. I have now added such a default clause. It will show an error message on the display informing the user about inadequate ADC button threshold levels in the init file that may cause SRAM emulation glitches.
Please install the new firmware (Version 1.5).
Overview
PicoRAM Ultimate is powered directly from the host machine; i.e., via the 5V and GND SRAM socket power pins.
To emulate SRAM, PicoRAM needs memory addresses, the 8bit data bus, as well as chip select and write enable signals. These are provided from either the 2112 sockets, the 2114 sockets, the 6116 socket, or the Heathkit expansion header.
The pinouts of these vintage SRAM chips can be found here:
2112 Chip
2114 Chip
6116 Pinout
The specs of these vintage SRAM chips are:
  • 2112: 256 x 4 bits
  • 2114: 1024 x 4 bits
  • 6116: 2048 x 8 bits
Whereas the primary mode of operation is to simply use ribbon cables connecting PicoRAM to the host machine's SRAM sockets, there is also an extension header option on the PicoRAM PCB that allows to neatly and directly connect PicoRAM to the Heathkit ET-3400. In this case, the address and data bus as well as the control signals are not supplied via the SRAM chip sockets, but over...
picoram_ultimate.uf2
PicoRAM Ultimate Firmware Version 1.2
uf2 - 152.50 kB - 06/22/2025 at 19:49
Download
et3400_decoder_16v8_gal.jed
GAL 16V8 JED File
jed - 618.00 bytes - 06/22/2025 at 19:49
Download
  • PicoRAM Ultimate Firmware V1.6 Released
    Michael Wessel5 days ago 0 comments
    The new firmware supporting the ET-3400A is now online!
    https://github.com/lambdamikel/picoram-ultimate
  • PicoRAM and the 6808-Based ET-3400A
    Michael Wessel6 days ago 0 comments
    ... got my hands on a Heathkit ET-3400A. This one has the much faster 6808 CPU. It took me a week to get the timing right, but eventually, I got there:
  • Three new "first steps" videos for PicoRAM Ultimate: ET-3400 + MPF-1
    Michael Wessel01/01/2026 at 02:20 0 comments
    Happy New Year - I had committed to build a PicoRAM Ultimate for a fellow ET-3400 enthusiast, and am wrapping up the year 2025 with three "first steps" videos that I made for new users:
  • Nasty firmware bug fixed
    Michael Wessel10/18/2025 at 14:06 0 comments
    I had a pretty nasty firmware bug encountered during my RetroChallenge 2025/10 contribution:
    https://hackaday.io/project/204153-3d-graphics-on-the-microprofessor-mpf-1b
    Basically, I was getting glitches and random CPU failures (crashes, SYS-REG, ...) At first I thought these were caused by my MPF-GRAFX card, but it turned out to be an issue with PicoRAM.
    This is fixed now:
    An uncaught "glitch" in the SRAM emulation due to noisy ADC button decoding. I have pushed a firmware update to PicoRAM Ultimate and PicoRAM 6116. The problem was that due to bad and noisy ADC thresholds button presses were detected that weren't real. Now, each time a button press is registered, the SRAM emulation is temporarily halted... but it requires the Z80 WAIT line to be connected, which I had not. This caused the issues. Obviously, you can't just halt SRAM emulation and not halt the CPU and expect it to run properly. The problem was fixed by adjusting the ADC threshold levels in the ULTIMATE.INI (or, 6116.INI). But I added some UI Error Message now if such a "spurious" button press is detected caused by noisy ADC and inappropriate analog threshold levels in the init file. Hopefully, this will make the effect at least visible if it should happen again to someone. Because it really was a head scratcher, given that there was no visible indication for this error other than the CPU crashing or glitching. Now we at least see what's going on, and can the manually adjust the thresholds in the init files. Phew!
    So, it wasn't really a "firmware bug", as it worked as intended. But, I wasted a lot of time chasing red herrings because the spurious button presses were happening without me becoming aware of them. This specific ADC button level fell through the button decoding "switch / case" in the UI thread running on the second core, and a default case was missing - this is where the error message is being raised on the display now to make the user aware that his ADC threshold levels in the init files are inadequate.
    Checkout the new firmware here:
  • My first MC6800 program - Towers of Hanoi on the Heathkit!
    Michael Wessel06/28/2025 at 13:38 0 comments
    Well, that was a bit of work to get that running... getting to know the side effects of the built-in firmware / monitor routines for driving the keyboard and display are always a bit of work! I almost went insane yesterday when sequences of `PSHA`, `PSHB` and ` PULB` and `PULA` op-codes consistently "transmuted" into `PSHA`, `PSHA` and `PULB`, `PULB`, and only when actually *running* the code... turns out there was still something slightly off with PicoRAM's timing, that oddly only showed up when accessing the stack. At first I suspected that there was something wrong with the assembler, ASM80.org, or that push/pull are only supported for the `A` accumulator, and that the MC6800 "would correct" these op-code "on the flx". I then replaced PicoRAM with the original 2112 SRAMs, and saw that the problem went away too - ops! After 2 hours of PicoRAM debugging I found that I needed to remove a few `NOP`s... and, problem fxed! There is a new firmware version, 1.3: https://github.com/lambdamikel/picoram-ultimate/blob/main/firmware/v1.3/picoram_ultimate.uf2
    Anyhow, after I understood how indexed addressing from the stack using `TSX` and `LDAA <offset>, X` works, I got it running - my first MC6800 assembly program. Thanks again to ASM80.org for hosting a very useful tool online. Here is the code, which might be instructive for anyhow trying to learn how utilize the ET-3400's built-in monitor / firmware ROM routines for their own programs:
    https://github.com/lambdamikel/picoram-ultimate/blob/main/software/et-3400/HANOI.A68
    I also uploaded the programs to the ET-3400 Google IO group here:
    https://groups.io/g/ET-3400/files/9.%20Sample%20Programs/Towers%20of%20Hanoi%20Assembly%20and%20Hex
    And, a video too - enjoy!
  • New programs for the Lab-Volt 6502 CPU Trainer - Towers of Hanoi!
    Michael Wessel06/23/2025 at 23:41 0 comments
    I ported the 6502-version of the Towers of Hanoi from
    https://rosettacode.org/wiki/Towers_of_Hanoi
    to the Lab-Volt trainer.
    It was fun to study the manual and learn how to use the firmware routines for input & output! My HANOI.RAM program can be found on the PicoRAM Ultimate GitHub, as well as the ".a65" assembly source code:
    I am also briefly showing two other programs that I found in the Lab-Volt course book; one IO LED PIA test, and a program that adds two numbers and displays the result. These programs are also in the GitHub repo. Enjoy!
  • New Firmware v1.2 Passes LabVolt RAM Test!
    Michael Wessel06/22/2025 at 19:48 0 comments
    I just learned (from reading the manual) that the LabVolt trainer comes with a built-in RAM test in ROM. So I tried it - and PicoRAM failed :-( Only "pages" `0x02` and `0x03` are user RAM on the LabVolt; page `0x00` is obviously the infamous 6502 Zero Page, and `0x04` is memory-mapped IO / hardware, specifically, the PIA sits there. As you know, in 6502 speak, a page corresponds to the high nibble of the 16 bit address, and hence, each page has 256 bytes.
    To start the RAM test, you write the start page (`0x02`) into memory cell `0x0000`, and the end page (`0x03`) to `0x0001`. Then you start the program from the ROM address `0xF6B1`. The program then goes through all the test patterns (bytes  `0x00` to `0xFF`) and writes and reads back every memory cell in all pages (inclusive and) between start- and end-page; here, from `0x0200`  to ` 0x03FF`, 512 bytes of user RAM.
    This test *failed* at first, and it failed quickly! It is surprising that the machine was working at all with the LabVOLT... I hence tweaked the firmware a bit by introducing two more `NOP`s when reading the address from the latches, and played with some GPIO settings. After a bit of back and forth, the RAM test finally succeeded!
    The firmware version 1.2 has been uploaded to the GitHub repo.
  • Firmware Update and PicoRAM Ultimate Galore!
    Michael Wessel06/21/2025 at 16:10 0 comments
    I fixed a slight firmware stability problem with the Microprofessor. The `CLOCK.RAM` program is a good stability test. It runs for hours now without any glitch / crash, so I am assuming that this problem has been fixed. At first I though it was due to noise or requiring 74F373 instead of the 74LS373, but these were red herrings. In the end, the GPIO slew rate and drive strength, as well as the hysteresis config were causing the problem. Fixed in Version 1.1 of the firmware now. And here is video showing all the machines with the new firmware:
  • GitHub repo online!
    Michael Wessel06/15/2025 at 18:47 0 comments
  • PicoRAM Ultimate 2nd PCB Revision Working!
    Michael Wessel06/11/2025 at 15:25 0 comments
    It just arrived yesterday evening, and I got up early this morning to check it out. It takes about one hour to assemble. A good stability test is the clock program for the microprofessor; if this runs stable for minutes, then everything is good wrt. timing and such. Passed!
View all 20 project logs
dmilholen wrote 06/24/2025 at 13:20 point
My issue is time I dont have.. I still have a day job. This is still my passion though and love to work in my shop every chance I get. I have a really awesome project I am working on involving both arduino atmega 2560 and the NUCLEO-H723ZG for an In Circuit Tester for 8 bit  arcade pcbs to help diagnose and repair more quickly.  It has been in my list of to-do for a very long time but each time I get started on it  some better technology comes along to make it better and add more features.
dmilholen wrote 06/18/2025 at 19:04 point
Jetzt sprichst du meine Sprache!
I love these old 8bit microprocessors and all the modern integration that can be done. I have been working with electronics and computers since 1980. I have degrees in industrial automation and tons of certs for telecom and networking but this is one of my favorite hobbies working in the shop repairing 80's arcade PCBs watching them come to life. I learned how to write machine code on the ET3400 back in the 90's :) I joined this just to be able to post and let you know how impressive you did on this project. When I get the time I want to build this and give it a try on my trainer. I also want to expand on this further using arduino and nucleo products.
Dave
Michael Wessel wrote 06/19/2025 at 01:25 point
Thanks Dave, that means a lot to me from someone like you who worked in the field since its infancy! Happy to collaborate on any further developments on that  - let me know how it goes when you get to it. Until then, cheers, Michael
