Supported
Supported machines (as of June 2025):
2112 Emulation for the stock, unexpanded Heathkit ET-3400 (4x 2112 SRAMs = 512 bytes):
Heathkit ET-3400 Memory Expansion Mode (2 KBs of 2112 memory; requires extra GAL 16V8 as an address decoder):
6116 Emulation (Microprofessor MPF-1B with 2 KBs of 6116 SRAMs; also see PicoRAM 6116):
2114 Emulation (Lab-Volt 6502 CPU Trainer with 2x 2114 SRAMs, 1 KB):
Last supported machine - the Philips MasterLab MC6400 (2x 2114 SRAM, 1 KB), a SC/MP III (INS8070) trainer from ~1985:
About
PicoRAM Ultimate replaces some (or all) of the RAM chips of these systems by emulating them in software with a Raspberry Pi Pico (RP2040) microcontroller, slightly overclocked at 250 MHz. PicoRAM is equipped with an SD card to store and load whole memory dumps to and from SD card. These memory dump .RAM files are similar to Intel HEX ASCII format and can be edited easily by hand on the PC. The utilized FAT file system facilitates data / file exchange with the PC or Mac.
PicoRAM Heathkit
Currently supported SBCs / host machines are:
The development logs are on Hackaday.
This project is a follow-up to PicoRAM 2090 for the Busch Microtronic Computer System and PicoRAM 6116 for the Microprofessor MPF-1.
Overview
PicoRAM Ultimate is powered directly from the host machine; i.e., via the 5V and GND SRAM socket power pins.
To emulate SRAM, PicoRAM needs memory addresses, the 8bit data bus, as well as chip select and write enable signals. These are provided from either the 2112 sockets, the 2114 sockets, the 6116 socket, or the Heathkit expansion header.
The pinouts of these vintage SRAM chips can be found here:
2112 Chip
2114 Chip
6116 Pinout
The specs of these vintage SRAM chips are:
Whereas the primary mode of operation is to simply use ribbon cables connecting PicoRAM to the host machine's SRAM sockets, there is also an extension header option on the PicoRAM PCB that allows to neatly and directly connect PicoRAM to the Heathkit ET-3400. In this case, the address and data bus as well as the control signals are not supplied via the SRAM chip sockets, but over the expansion header. A dedicated address decoder is used in this case (GAL16V8).
PicoRAM generates a READY/BUSY/HALT signal for the CPU in order to suspend CPU operation while it cannot serve the RAM content (i.e., during file or UI operations). Power (VCC = 5V and GND) is fed in from the sockets and connectors as well (i.e., whatever socket / connector is being used to connect to the host machine supplies power to PicoRAM).
PicoRAM has a convenient OLED-based UI. The hexadecimal ASCII-based file representation of the memory content and FAT32 file system facilitates editing and exchange of memory dumps (programs and data) with a PC or Mac.
PicoRAM also offers an auto-load function - programs can be loaded automatically into the host machine when it powers up (as if these were EPROM-based programs).
A number of jumpers must be set to match the host machine. These jumper settings can be found on the PCB as well:
Jumper Settings
Features
User Interface
The PicoRAM OLED display (if not turned off) shows the currently loaded RAM file, the machine type, and the current bank number:
Display
On the main screen, the 5 buttons have the functions listed in the legend:
Buttons
During file operation (i.e., when a file is loaded from or saved to SD card), the buttons take on additional functions for file selection, file name creation, to confirm or cancel operations, and so on. It will be obvious (i.e., intuitive) how to use them.
The ULTIMATE.INI Configuration / Initialization File
The 5 UI buttons are read over an analog input on the Pico and mapped to a value within the HEX interval 0x000 - 0xFFF by the Pico's analog-to-digital converter (ADC). The different buttons produce different values in this range. Unfortunately, the analog levels on the Pico are very noisy and also vary from machine to machine, depend on the host machine power supply, etc. These ADC values for the different buttons are mapped to specific UI buttons by means of thresholds; e.g., an ADC value below 0xA00 but higher than 0x800 means the CANCEL button has been pressed, a value within 0x500 to 0x800 corresponds to a push of the OK button, and so and so forth. These threshold intervals are specified in the ULTIMATE.INI file.
Note that proper thresholds are extremely important for a reliable and error-free operation of PicoRAM. Every time a UI button push is detected, the Pico onboard LED will be lit and RAM emulation is paused by pulling down the WAIT/READY/BUSY line of the host system CPU. If PicoRAM should detect false (random, spurious) button presses due to ADC fluctuations and noise, then it is likely that the CANCEL button threshold is set too high. Or, if you are not getting the right function for a button (e.g., the CANCEL button acts as the OK button), then the thresholds must be adjusted to match your machine as well. There are two methods for "tuning" these thresholds, which are described in the next subsection. But first, let us discuss an example ULTIMATE.INI file (here, for the Philips MasterLab):
MASTERLAB
F00
F00
B00
800
500
200
NIMM.RAM
HEXCOUNT.RAM
NUMGUESS.RAM
0
(note that UNIX EOL is required here - a single newline / 0x0A character!).
The file lists, in this order:
So how do we dermine these analog threshold values in case the supplied default init file doesn't work for your machine? Read further.
Determining Analog Button Thresholds
There are two methods:
  1. The PicoRAM firmware contains a Button Tuning function which allows you to acquire the threshold values interactively. You are being asked to push each buttons 5 times, and at the end, you will have the option to write the acquired threshold values to an ADC.INI file on SD card: Tuning
    This file can then be hand-edited and become the basis of a proper ULTIMATE.INI file. This Button Tuning functionality can be invoked by holding down any button during start-up / reset of PicoRAM. Examples of proper init files can be found here.
  2. If you start PicoRAM from an ULTIMATE.INI file that has a 1 entry as its last line, it will start an infinite loop, displaying the analog values as they are being read. You can determine the threshold for each button by inferring a safe upper bound from the values you are observing. For example, in this picture we are observing (noisy) values for the OK button in the 0x800 to 0x8F0 range: Tuning
    A threshold value of 0x900 would hence be a good choice for the OK button threshold in the ULTIMATE.INI file (4th line).
Host Machine-Specific Configuration
PicoRAM supports multiple host machines / SBCs. A machine type-identifier in the first line on the ULTIMATE.INI file determines the machine type.
The following types are supported; each host system is described in more detail below.
Stock Heathkit ET-3400 without Expansion Header
The Heatkit ET-3400 is a Motorola MC6800-based CPU trainer from ~1976 and can be considered as one of the very first CPU trainers.
The stock system came with only 2 2112 SRAM chips (IC14 and IC15), amounting to 256 bytes. Users could upgrade the machine to 512 bytes by plugging in two more 2112 SRAMs into IC16 and IC17. PicoRAM connects to IC14 and IC17 and can emulate 512 bytes of memory in the address range 0x0000 - 0x01ff.
ET-3400 Stock Config
ET-3400 Stock Config 2
Note that this applies to the ET-3400 with original MC6800 CPU with no upgraded crystal, and that you will need a jumper cable from the HALT pin of PicoRAM's J3 header to the ET-3400's HALT breadboard connector, as shown in the above picture.
The machine type string (1st line in the ULTIMATE.INI) is ET3400.
The jumper configuration for this mode is:
U
JP2 JP4 JP6 JP8 A9
L R R L U
Where * = don't care and for N:
Stock Heathkit ET-3400 with Expansion Header
If your ET-3400 has the expansion header installed, PicoRAM Ultimate can upgrade your machine to 2 KBs, address range: 0x0000 - 0x07ff.
ET-3400 Expanded 1
Note that this applies to the ET-3400 with original stock MC6800 CPU with no upgraded crystal with an installed (and fully wired-up) expansion header.
The machine type string (1st line in the ULTIMATE.INI) is ET3400_EXP.
PicoRAM plugs onto the expansion header:
ET-3400 Exp.Header 1
In particular, it is assumed that the databus wires have been soldered in (by default, the PCB only accommodates for the address bus and the control signals!), as well as the RE signal:
ET-3400 Exp.Header 3
The databus and RE signal mods are also described in the IO extension box manual.
ET-3400 Exp.Header 4
The pinout of the expansion header is as follows:
Note that the RE signal is shown as NC in this pinout, between A12 A13 and A2 A3. Unlike depicted by Pictorial 1-6, the resistor and diode are not required for PicoRAM Ultimate. However, if already fitted and installed, they shouldn't cause problems for PicoRAM either (but I haven't tried). Alternatively, you can simply route a jumper wire from the RE pin of PicoRAMs J3header to the corresponding breadboard connector (but the expansion portRE` connection is cleaner).
For this mode, the 16V8 GAL chip U10 must be installed, as the RAM select signal can not longer be generated from the SRAM sockets, due to the larger address range. Here are the (optional) GAL source and the required JED firmware file (i.e., for programming a 16V8 GAL with a standard TL-866 EPROM programmer and MiniPro).
The jumper settings are as follows:
D
JP2 JP4 JP6 JP8 A9
R L L L D
ET-3400 Expanded 2
Lab-Volt 6502
The Lab-Volt 6502-based CPU trainer was released by FESTO Didactic in the early 1980s; apparently, the machine was being manufactured at least until 1999 - my accompanying textbook copy is the "16th printing, 1999". The trainer is equipped with 2 2114 SRAM chips (1 KB of RAM):
Lab-Volt
The machine type string (1st line in the ULTIMATE.INI) is LABVOLT.
D
JP2 JP4 JP6 JP8 A9
R R L R D
Moreover, the JP5 setting for 2 KBs
does not work for the Lab-Volt - but might work for a different host machine with 4 2114 chips. Check the schematics.
Lab-Volt 2
A jumper wire must be routed from the HALT pin on J3 to RDY (22) pin on the machine's system bus header (top-left header).
The Philips MasterLab MC6400 is a INS8070 (SC/MP III)-based CPU trainer released in ~1984. Despite the Philips label, the machine was only released in Germany, and likely developed in my birth town, Hamburg / Germany. More infos can be found here. It is equipped with 2 2114 SRAM chips (1 KB of RAM):
MasterLab
You will have to modify your MC6400 and put in sockets to accommodate PicoRAM as follows. The PCB is of very good quality, and with a little bit of soldering skills you will have no issues accomplishing this:
MasterLab Mod 1
MasterLab Mod 2
The machine type string (1st line in the ULTIMATE.INI) is MC6400.
D
JP2 JP4 JP6 JP8 A9
R R L R D
Where * = don't care and for N - emulate
does not work for the MasterLab - but might work for a different host machine with 4 2114 chips. Check the schematics.
Note that a jumper wire is required that connects the HALT pin of the J3 header to the MasterLab's Master Reset as follows - this is the first top-most connector socket that is not occupied by a wire bridge:
MasterLab Mod 2
It can be seen more clearly in this pinout diagram:
MasterLab Connector
Multitech Microprofessor MPF-1
The company Multitech (nowadays: Acer) released a series of Z80-based trainers as early as 1981 (MPF-1); later models included a Palo Alto TinyBASIC EPROM (MPF-1B), and the much more powerful and capable MPF-1P (One Plus) that featured an alphanumeric keyboard and VFD, had a symbolic 2pass assembler with line editor, a full floating point BASIC, and Forth! More info about these fascinating machines can be found here.
The machine type string (1st line in the ULTIMATE.INI) is MPF. PicoRAM emulates one 6116 chip and supplies 2 KBs of SRAM.
Ultimate MPF
The jumper settings are:
D
JP2 JP4 JP6 JP8 A9
L R L L D
On the MPF-1(B), PicoRAM should be plugged into the U8 6116 socket. For the MPF-1P, the U5 6116 socket should be used.
For U8 on the MPF-1(B), the 2 KBs of RAM usually appear in the address range 0x1800 - 0x1FFF. On the MPF-1P, U6 is mapped to 0xf800 - 0xFFFF.
The HALT pin of the J3 header needs to be connected to pin 37 on the MPF's (1, 1B, 1P) primary (top-left) extension header via a jumper wire. Double check JP1 as well; for the Microprofessor, it needs to be set to R (for CE, pin 18).
Also have a look at the predecessor project, PicoRAM 6116.
Host Machine-Specific Software and Example ULTIMATE.INI Initialization Files
PicoRAM uses a FAT32-formatted (max 32 GB) Micro SD Card.
To get started, you can simply copy the sub-directory for the intended host machine from the software/ directory.
Theory of Operation
The Raspberry Pi Pico emulates the SRAM of the host machine and is overclocked to 250 MHz to make this possible; this is completely in the safe range and does not affect the longevity of the RP2040 in any negative way.
Due to a lack of GPIOs on the Pico, two 74LS373 transparent octal latches are used to multiplex the (max) 11-bit address bus. The (up to) 11-bit address is read in two batches of 6 and 5 bits, using the SEL1 and SEL2 signals from the Pico to OE (Output Enable) the first resp. second latch. The latches are merely used for their tri-state capabilities.
Unlike my previous design, PicoRAM 2090, this design does not utilize any voltage level converters. It turns out that the Pico (RP2040) is really pretty much 5V-tolerant; also see this article from Hackaday and the Hackaday coverage of PicoRAM 2090.
Development 1 Development 2 Development 3 Development 4
More details about the making of the project, and technical notes / development logs can be found on the PicoRAM 6116 Hackaday project page and the PicoRAM Ultimate Hackaday project page.
The Board
Schematics
Schematics
Here is a PDF of the schematics.
Printed Circuit Board (PCB)
The current version is Rev. 1, June 2025.
PCB
There is also a Bill of Material (BOM).
Note that the resistor array should be 1K. The 2112, 2114, 6116 chips are only sockets, obviously (so you don't actually need to purchase any SRAM chips - PicoRAM emulates them).
Gerbers
Gerbers
See here.
Firmware Image
The current version is 1.0, June 2025. The .uf2 image can be found here.
Firmware Sources
See here.
Acknowledgements
