Solar powered 24hr timelapse photography
A project using a solar powered Raspberry pi to wake up at midday and take a photo, each day for a year
Raspberry Pi 5 has a ‘low power’ feature plus a Real Time Clock, which has a ‘wake up’ capability.
Seconds to wake up time can be inserted into a file which is read on going low power (Linux ‘shutdown’ but retaining power to the board). After the given seconds, the board powers up again.
This suggests a time lapse project:
I would like to take a mid-day photo of some apple trees throughout a year, to stitch in a film showing snow on bare trees, spring blossom, leafing up, growing apples, falling leaves.
Due to difficulty of getting power to the garden, I’m thinking of:
Solar panel plus battery with raspberry pi with camera, all boxed up and mounted.
Pi in low-power mode apart from brief mid-day on-time for the photo, plus an evening on-time to give myself a chance to connect and pull down photo’s or do any changes.
Bought: RaspberryPi 5, 2GB version running Raspberry OS Lite, with a passive heatsink to give the lightest load. Set with parameter "POWER_OFF_ON_HALT=1" to reduce load during off phase.
From RPi docs, for RPI5, to enable low power mode and wakeup with the Real Time Clock:
    $ sudo -E rpi-eeprom-config --edit
    and edit the following line
    POWER_OFF_ON_HALT=1
    test with
    $ echo +600 | sudo tee /sys/class/rtc/rtc0/wakealarm
    $ sudo halt
This sets on time to ten minutes, then powers the Pi off, after 10mins it should auto power on again.
Current status
Python program written to set the next required on time into the /sys/class/rtc/rtc0/wakealarm location and then power off. Currently during the testing phase the program, during the mid-day on time, simply saves a file containing a timestamp string rather than taking a photo. This tested, and powers up automatically at the right times, then powers down. The timestamp files are saved regularly. The Pi on-switch can be used to turn the Pi on at any time, which gives five minutes before the Pi auto shuts down again. So the user has five minutes to connect, and if required abort the shutdown.
The Python files are on this site, as power.py and also a systemd service file, power.service which is used to ensure power.py is run on boot up.
Obtained: two 2W, 6V solar panels, batteries, power management unit, pi plus camera module3.
Next step, change python file to take photos, wire all together and test it works. Then build box and stand for the whole lot.
power.service
Systemd service file to start power.py on boot up
x-dbus-service - 380.00 bytes - 05/18/2025 at 11:48
Download
power.py
Python file to wake up at midday, take photo and shut down, then wake up at 18:00 for ten minutes for any required remote access.
x-python - 4.86 kB - 05/18/2025 at 11:47
Download
  • 1 × RaspberryPi 5 2GB version Pi5 has low power option, 2GB is lowest power version of the Pi5's
  • 1 × passive heatsink for Raspberry Pi 5 I used 'Low-profile Heatsink for Raspberry Pi 5' from PiHut, SKU: 105875
  • 2 × 6V 2W Solar Panel - ETFE (Voltaic P126) Small solar panel, purchased from PiHut
  • 3 × 18650 Lithium-ion Rechargeable Cell - 2500mAh 3.7V Batteries for solar power manager
  • 1 × Panel Mount Kit for Raspberry Pi Camera Module 3 Used to mount camera in box.
View all 7 components
  • Power Management unit
    bernie05/29/2025 at 10:14 0 comments
    Bought the power management unit and three batteries:
  • Solar Panels bought
    bernie05/22/2025 at 10:13 0 comments
    Bought two 2W solar panels, hoping this will give enough output.
    And another shot:
  • Test script as SystemD service
    bernie05/20/2025 at 14:35 0 comments
    Initial test script power.py loaded as a systemd service. This simply saves a datetime line to a file to show the Pi is waking up at midday each day.
    Create a file :
    /lib/systemd/system/power.service
    containing the following (with paths adjusted for your own script location):
        [Unit]
        Description=Runs Timelapse power cycles
        After=multi-user.target
        [Service]
        Type=idle
        ExecStart=/usr/bin/python3 /home/bernard/git/timelapse/power.py
        WorkingDirectory=/home/bernard/git/timelapse
        Restart=on-failure
        # Connects standard output to /dev/null
        StandardOutput=null
        # Connects standard error to journal
        StandardError=journal
        [Install]
        WantedBy=multi-user.target
    Then set permissions of the file
    sudo chown root:root /lib/systemd/system/power.service
    sudo chmod 644 /lib/systemd/system/power.service
    Enable the service
    sudo systemctl daemon-reload
    sudo systemctl enable power.service
    This starts /home/bernard/git/timelapse/power.py on boot up.
    Useful functions to test the service:
    sudo systemctl start power
    sudo systemctl stop power
    sudo systemctl restart power
    sudo systemctl status power
    sudo systemctl disable power
    Display last lines of the journal
    sudo journalctl -n
    Display and continuously print the latest journal entries
    sudo journalctl -f
  • Estimated power budget
    bernie05/18/2025 at 12:42 0 comments
    Power budget:
    Note: the 2GB version of the Pi5 has a tested current of less than 1A when running with lite OS, though possibly with a peak current higher than this on startup.
    Assume on-time of 20 mins, energy used by Pi:
    5V * 1A * 0.33h  = 1.7 watt hours (Wh)
    Assuming 0.05 Watt for standby during rest of day
    0.05W * 24h = 1.2 Wh.  (ignoring 20 mins less)
    Total energy required for 24hr = 3.0 Wh
    Waveshare power management unit, has 3x18650 Li-ion, and can give 3A output - so the possible higher startup current of the Pi is covered.
    Batteries are rated 3.7V, 2500mAh
    Max battery energy capacity 3 x 3.7V x 2.5Ah = 27.75 Wh
    So fully charged batteries have plenty of capacity.
    Assuming 6V 2.0W Solar panel available from PiHut.
    Assume UK weather only gets 1W, then after four hours of daylight:
      1.0(W) x 4(h) = 4.0 Wh
    So should get the 3Wh energy required per 24hr.
    However after further consideration: UK winter sun may produce less than 1W. This solar panel is advertised as 6V. If panel output drops below 6V, then the management unit may fail to work as it is advertised for an input of 6V and above. So decided to get two 6V solar panels and wire them in series to get a nominal 12V, together with the increased wattage output.
  • Low power usage
    bernie05/18/2025 at 12:07 0 comments
    In the off state (but retaining power to the board) power can be minimised with:
        POWER_OFF_ON_HALT=1
    The meter shows no current on power down (which can't be right since there's a red LED lit like the eye of Sauron), I'll guess 0.01 of an Amp, so power is 5v x 0.01a = 0.05w
  • Power demand
    bernie05/18/2025 at 12:02 0 comments
    Estimating power requirements. Raspberry Pi 5, 2G version, with passive heatsink. Testing the usb-c line gives around 0.5 Amp on powered up.
View all 6 project logs
bernie wrote 05/29/2025 at 10:39 point
Power budget:
Assuming 0.05 Watt for standby during rest of day 0.05W * 24h = 1.2 Wh.  (ignoring 20 mins less)
