Test script as SystemD service
A project log for Solar powered 24hr timelapse photography
A project using a solar powered Raspberry pi to wake up at midday and take a photo, each day for a year
berniebernie 05/20/2025 at 14:350 Comments
Initial test script power.py loaded as a systemd service. This simply saves a datetime line to a file to show the Pi is waking up at midday each day.
Create a file :
/lib/systemd/system/power.service
containing the following (with paths adjusted for your own script location):
    [Unit]
    Description=Runs Timelapse power cycles
    After=multi-user.target
    [Service]
    Type=idle
    ExecStart=/usr/bin/python3 /home/bernard/git/timelapse/power.py
    WorkingDirectory=/home/bernard/git/timelapse
    Restart=on-failure
    # Connects standard output to /dev/null
    StandardOutput=null
    # Connects standard error to journal
    StandardError=journal
    [Install]
    WantedBy=multi-user.target
Then set permissions of the file
sudo chown root:root /lib/systemd/system/power.service
sudo chmod 644 /lib/systemd/system/power.service
Enable the service
sudo systemctl daemon-reload
sudo systemctl enable power.service
This starts /home/bernard/git/timelapse/power.py on boot up.
Useful functions to test the service:
sudo systemctl start power
sudo systemctl stop power
sudo systemctl restart power
sudo systemctl status power
sudo systemctl disable power
Display last lines of the journal
sudo journalctl -n
Display and continuously print the latest journal entries
sudo journalctl -f
