Streetlight controlling using Dragino LC01 LoRaWAN
Build LoRaWAN Class C enabled Streetlights
In this project, you will learn how to wirelessly control a STREETLIGHT using LoRaWAN (Long Range Wide Area Network) technology. We demonstrate this by using the Dragino LC01 LoRaWAN relay module, which acts as a remotely controlled switch. The project walks you through the setup process, including how to connect the LC01 relay to a the streetlight, configure it to communicate over a LoRaWAN network, and send control commands through a network server (such as The Things Stack v3). By the end of this tutorial, you will be able to turn an appliance on or off remotely using a low-power, long-range wireless connection.
LC01 LoRaWAN relay
The Dragino LC01 is a LoRaWAN®-enabled relay controller designed for smart control of electrical appliances and lighting. Ideal for remote switching and status monitoring, the LC01 is built to deliver reliable performance in demanding environments.
Key Features:
  • Wide Voltage Support: Compatible with appliances operating from 80–275V AC, with a maximum resistive load of 15A.
  • Dual Terminal Design: Equipped with two input and two output terminals for easy power connection.
  • LoRaWAN® Class C: Operates in Class C mode for low-latency communication and continuous listening.
Built-In Protection & Durability:
  • Advanced Safety: Integrated protection against overcurrent, overvoltage, short circuits, and temperature rise, helping reduce the risk of damage from lightning strikes.
  • Rugged Enclosure: Made from fireproof PC material with UV-resistant additives, ensuring long-term durability without discoloration.
Plug & Play Connectivity:
  • Preloaded Credentials: Comes with a unique DevEUI,  AppEUI, and AppKey, enabling fast and secure registration on any LoRaWAN network.
  • Auto Join Capability: Automatically connects to the pre-registered network once powered on.
Longer Life with Zero-Crossing Trigger:
  • The LC01 includes a patented zero-crossing trigger, which minimizes electrical stress and extends the device’s operational life.
  • 1
    Identifying LC01's Terminals
    The LC01 has four terminals. Two terminals for input and two terminals for output. These terminals accept AC voltage between 80-275:
    Caution: Do not supply voltage beyond the maximum voltage range.
    Terminal Description (LC01)
    IN
    • L – Input Live (L)
    • N – Input Neutral (N)
    OUT
    • L – Output Live (L)
    • N – Output Neutral (N)
  • 2
    LED Streetlight connections
    • 1 – Live (L)
    • 2 – Neutral (N)
    • 3 – Earth (E)
  • 3
    Connect the mains plug to the LC01
    Strip about 1 inch of the outer insulation from the cable. Then, strip the insulation from the blue and brown wires. The green wire is not used.
    Using a Phillips head screwdriver (make sure it matches the size of the screws), loosen the two IN L and N screws by turning the screwdriver counterclockwise. Do not over-loosen the screws, as this may cause them to fall out of the terminal. As you loosen the screws, you will notice a widening gap between the plastic housing and the metal terminal.
    • Connect the other end of the LIVE wire (usually brown) to the terminal IN (L). Then, using the screwdriver, tighten the screw clockwise.
    • Connect the neutral wire (usually blue) to the terminal IN (N). Don’t tighten the screw yet because this terminal share the both input and output.
View all 9 instructions
