Cheap Chinese wifi switches that turn out to be quite hackable
Managed to whip up a programming jig with some wire, bread board, pin headers, plastic and some hot glue.
After following the traces back I was able to power up the micro-controller for programming.
from amazon:
"Question: Does it work with Alexa dot?
Answer: Revising answer below to YES!!! Download the Tuya Smart App instead of the UCSmart App on the directions. With the Tuya Smart app you can then pair with Echo Dot (Alexa). Just did mine.
(this is the Hausbell 701U, worth a try on the AUOSMART?)
The switch was this one https://www.amazon.com/gp/product/B01HNYC26K
But this 2 pack of a different brand also looks to be the same exact board.
I can recommend the sc20 series of esp8266 based switches itead makes. The switches are a bit cheaper than what was linked from amazon. The board design is fairly impressive for a chinese product and would have no problem getting a CE certificate if the transformer is of similar high quality.
https://www.itead.cc/smart-home/smart-socket.html
Oh, and there is a wiki with inside pictures hosed by itead. There are also what seems like countless projects for custom firmwares for it :)
