1Instructions:
Body build Instructions:
(DONT forget to follow the wire diagrams added in the files project)
- press 3 thread inserts into the right body part, as you see in the picture below.
2. Connect the two halves of the body with 3 M3x8 screws
3. Press 2 heat inserts into the left body part, and screw in the PCB with 2 M3x5 screws
4. Hot glue the temperature sensor (don't forget to wire it!) to the right body part ( make sure the temp sensor is showing through the hole).
5. Wire and hot glue the 3 touch sensor into the top of the body assembly.
6. Press the 16 heat inserts into the diffuser 2 parts.
7. inserts the LED matrix and close everything with the 4 LED Support parts using M3x5 Screws. Connect the two halves of the diffusers with the Diffuser Connector and 2 M3x8 screws.
8. Finish the assembly with 6 M3x8 Screws and connect the body with the diffusers.
n8n instructions:
in the project here, you have .json flies (example YouTube.json), this files are the automation workflow that n8n will run to send information to the display. the code is already ready! all you have to do is just add your information.
DO THIS FOR ALL THE WORKFLOWS:
Start with:
Open n8n: and press “Create Workflow”
Press the 3 Dots on the top right, import from file, and import the JSON file you want.
Now follow the instructions under the correct json file (for example Tiktok)
COME BACK HERE after you finish with the json instructions and do this:
AFTER changing everything you need to change in the json (check the instructions below)
for every json, you will also need to download the icon to your display, go to the social media flow, go to send to clock, scroll down until you will see ICON and copy the numbers:
Go to your favorite browser, go to the display IP, go to icons, paste that number there and press download, that will load the icon to the display memory,Tiktok:
after loading the json, double click on fetch data, and add your username instead of “ChangeMe”
Under Send to Clock and Remove app, Change the IP to the IP of the Display:
Now go back and do the Icon download.
Youtube:
You will need to create a project in Youtube Developer, (full instructions in this video).
You will need your channel ID and your API Secret key.after loading the json, double click on fetch data, and add your ID and Secret KEY instead of “ChangeMe”
Instagram:
after loading the json, double click on fetch data, and add your Instagram name under username. (replace the ChangeMe).
Reddit:
after loading the json, double click on fetch data, and add your Reddit name under username. (replace the ChangeMe).
Twitch:
- Go to Twitch Developer Console, Press on Register your Application.
- Name -
whatever you want
. - OAuth Redirect URLs -
http://localhost:5678/rest/oauth2-credential/callback
. - Category -
Other
. - Go back to Dashboard and press on your
Mange
on your new app. - Copy
Your Client ID
, PressNew Secret
, And copy yourSecret Code
. - Go to this Website, and get your
Twitch Broadcaster ID
Now we have everything we need, go back to n8n and load the Twitch Json file.
Press the Fetch Data, Under OAth2 API pressCreate New Credentials
In the new window fill all the inforrmatin needed:
- under
Grant Type
chooseClient Credentials
. - under Access Token URL add
https://id.twitch.tv/oauth2/token
. - add your
Client ID
from the previous step. - add your
Client Secret
from the previous step. - Under Scope add
moderator:read:followers
. - under Authentication choose
body
Go back to fetch data window, scroll down, under
Broadcaster ID
add the Broadcaster id we got from the previous step. (the website). And underClient ID
add your Client ID again.Now go back and do the Icon download.
