Boat with Arduino-Controlled Anchor System
We designed a motorized mini-boat controlled by an Arduino, capable of raising and lowering an anchor using a motor and a gear system.
This is a school project. We made a small boat with one motor and an Arduino. The motor is not for moving the boat, but for dropping and lifting the anchor. We 3D-printed these parts: the boat, a spool, and a gear. The anchor is a small metal weight. When we press a button, the motor turns and the anchor goes down. If we press the button again, the anchor goes up. We used: Arduino Uno L298N motor driver 1 DC motor Push button 3D-printed parts The code is simple. It controls the motor direction. The boat does not move by itself, but the anchor system works well. We tested it in water, and it was a success.
What we need so far :
  • 1 Arduino Uno
  • 1 L298N motor driver
  • 1 DC motor 6V
  • 1 push button
  • 1 anchor (metal weight)
  • 1 spool (3D printed)
  • 1 anchor support (3D printed)
  • 2 boat hulls (3D printed)
  • 1 battery holder (4x AA, 6V total)
  • 1 waterproof box (optional)
  • LED indicator for anchor status (optional)
Catamaran V1 :
  • Manual anchor control with button
  • Anchor can be lowered/raised using a DC motor
  • Printed catamaran hulls
  • Fully functional anchoring system tested in water
  • Simple electronics (no sensors)
Catamaran V2 ideas :
  • Remote control (Bluetooth or RF)
  • LED to show anchor status (down/up)
  • Sound alert when anchor moves
  • Waterproof housing for outdoor use
  • Add solar charging for battery
Catamaran v1.stl
Standard Tesselated Geometry - 268.05 kB - 06/19/2025 at 23:32
Download
Video conception 3D.mp4
MPEG-4 Video - 265.11 kB - 06/19/2025 at 23:25
Download
Catamaran v1 conception 3D.stl.glb
glb - 379.55 kB - 06/19/2025 at 23:21
Download
Wiring management.pdf
final cable management
Adobe Portable Document Format - 4.92 kB - 06/19/2025 at 23:28
Preview
Catamaran V1.brd
brd - 33.72 kB - 06/19/2025 at 23:18
Download
View all 18 files
  • 1 × Arduino Uno main controller of the system
  • 1 × L298N Dual H-Bridge Motor Driver used to power and control the motor
  • 1 × DC Moteur (6V) activates the spool for lowering the anchor
  • 1 × 3D-Printed Spool to wind/unwind the anchor cord
  • 1 × Simple Gear System increases torque for the anchor mechanism
View all 13 components
  • What we could improve
    Aruketty06/20/2025 at 02:08 0 comments
    - Anchor wouldn’t go up :
     Near the end, the anchor couldn’t lift back up as expected. We’re not sure if the issue was due to the code logic, a wiring problem, or even motor torque. The spool turned correctly in the “down” direction, but the reverse direction failed. More time for debugging or testing with different motors would help pinpoint the issue.
    - Add a second button :
    We originally used a single button to cycle between down → stop → up → stop. But it sometimes caused confusion. We wanted to add a second push-button, one dedicated to lowering and one to raising the anchor. This would make the system easier to understand and safer to operate.
    - Endstop sensors :
    The anchor currently runs until the user stops it. Adding limit switches or an encoder to detect the anchor’s position would avoid over-rotation and protect the system from jamming or tangling.
    - Waterproofing :
    The electronics were exposed during tests. To make it more robust, we have to enclose the Arduino and driver in a splash-proof case or use conformal coating.
    So, there are all the points that we should have brought to complet this project nicely. Of course, we should have been more involved and diligent to move forward much more quickly. To conclude, with some recoil, it was a nice project to share with my team mates because it required leadership skills, efficiency, time management and many other good things.
  • Real-World Test
    Aruketty06/20/2025 at 00:28 0 comments
    There is only one thing left for us to do, test it on water !
  • Programming
    Aruketty06/20/2025 at 00:26 0 comments
    We wrote a simple but functional Arduino sketch using a state machine:
    • First button press make anchor goes down
    • Second press make it stop
    • Third press make anchor goes up
    • Fourth press stop it another time
      Then the cycle repeats. The problem is that we have not add a captor who can say when the anchor touch the floor so the anchor is going full.
       Part of the code when the anchor goes down :
    digitalWrite(in3, LOW);
    digitalWrite(in4, HIGH);
    analogWrite(enb, 180);
  • Tinkercad Wiring Simulation
    Aruketty06/20/2025 at 00:17 0 comments
    To ensure our wiring was correct, we built a full simulation in Tinkercad. It helped us verify the connections before physical assembly.
    With that you can check our wiring management :
  • Electronics Setup
    Aruketty06/20/2025 at 00:11 0 comments
    Nous avons utilisé :
    • 1× Arduino Uno
    • 1× L298N (pilote de moteur à pont en H)
    • 1 moteur CC 6 V
    • 1× bouton-poussoir pour la saisie utilisateur
    • 1× 4×AA batterie (≈6V pour l'alimentation du moteur)
    • Fils de liaison
  • Mechanical assembly
    Aruketty06/20/2025 at 00:06 0 comments
    We attached the spool to the shaft of a small DC motor and installed it between the two hulls. A small metal weight serves as the anchor. When the motor rotates, the spool winds or unwinds the rope, raising or lowering the anchor depending on direction. It's a bit dirty but it's just a prototype, we wanted it to work first and foremost.
  • 3D Design & Printing
    Aruketty06/20/2025 at 00:00 0 comments
    We began designing the catamaran by modeling two symmetrical hulls and a central support to accommodate the electronic components. We also designed a spool to wind the anchor line, and a gear to connect it to the motor !
View all 7 project logs
  • 1
    3D-print the parts
    - Use a 3D printer to make the boat (2 parts). The advantage about our boat is that there is no need to do a lot of assembly.
    So there is the modelisation :
    - For the spool and the anchor we dont use a print because we found it at our lab, but there, are prints that we wanted to use at first :
  • 2
    The boat
    The catamaran hull was 3D printed with plastic material. Its total size is:
    • Length: 24 cm
    • Width: 14 cm
    • Height: 8 cm
    This makes it compact enough for testing in a sink or small container. The central slot is sized to fit a small DC motor and spool system. As well the batterie is inside the boat.
  • 3
    Assemble the hulls
    -Slide the motor mount into the slot, flush with the rear of the boat.
    -Feed a 40 centimeters length of nylon fishing line through the deck hole and tie it to the spool. (ps: it is an prototype so we dont need a super long string)
View all 8 instructions
