Background
Recently I have been moving to a new city (again) for a new job position. I have been moving home for a few time in my life and since I have no family members living locally, every time I move I have to do all the hard-work myself, including moving my whole electronic workshop to a new location. It is fine for small parts or tools but for heavy, bulky things like my first (full sized) hotplate and DC power supply, I rather just give it to my local friends and buy a new one when I arrive to the new site.
That is why after this move, I have been thinking, would it be faster if I could shrink all my heavy tools in my workshop into something small and lightweight where I can just move them with me with a cardboard box next time I move?
That is why I am constantly replacing my tools with more lightweight, pocket sized options.
Running a small batch production for my friends
When I first started this project, it was just a personal DIY challenge—I wanted to build a compact, adjustable PD power supply that could run off USB-C. The initial design was pretty complex, with high-precision current sensors and a tightly packed layout. It worked, but I quickly ran into problems when I thought about making more of them or sharing the design with others. The cost was high, and it just wasn’t easy to reproduce, especially for hobbyists with limited time & tools.
That’s when I decided to simplify things. I reworked the design to use more accessible components and made it easier to solder by hand. I also teamed up with PCB Way, who kindly sponsored the PCBA process. Their support really helped turn the project from a one-off prototype into something that could be manufactured and shared more widely.
Still, even with PCBA service, there are quite some assembly process that needed to be done manually. In order to make enough of the units so I can give it to my friends in the education and maker fields, I decided to start another collab with HCCLAB, which is a local maker fab community that could help assemble 50% of the boards I plan to build. That finally make a small scale production run possible.
Now the whole design—hardware and firmware—is open source and up on GitHub.
tobychui
