Conways Game of Life on a LED Cube
Conways Game of Life on a LED Cube with 16x16 LED on each side
Conway's Game of Life was one of the first programs I programmed on my CPC (in Amstrad Basic). Now I built a Cube with LED, controlled by an Arduino, to play that Game of Life.
Short summary:
* Controller: Arduino Uno
* 24 MAX7219 matrix controller
* 1536 LED 0805, red
* custom PCB
Why this project?
  1. Conway's Game of life would be a nice blinky blinky :-)
  2. Just a plane LED panel? Boring
  3. Infinite area would be nice, ideally a globe but.... that would be the next step (how do I place cells on a globe evenly, ideally with each cell 8 neighbours?)
  4. So a cube.
The plan:
  • Should run with a Arduino Uno/Nano
  • 16x16 LED on each side of the cube
The "final" implementation:
  • (Is it really final?)
  • Arduino Uno
  • 24 LED Panles with
    • MAX7219
    • 64 red 0805 LED
  • Custom PCB
  • 3D printed support
  • 7219 library with SPI
  • First tests and new library
    Christian2 days ago 0 comments
    To see, if my idea work in principle, I build it all using MAX7219 modules from AZ delivery:
    The test showed:
    • My Idea in general is working :-D
    • The library that is available on github was not sufficient.
      • It used bitbanging for the communication
      • It was only able to handle up to 8 MAX7219
    So I implemented a new library using SPI and also allowing more modules (tbd: github link ;-)
    The new library was x times faster (tbd: videos)
    Why not simply take the already made modules: because they are sooooo thick and the edges of the cube would be not nice. Next step: custom PCBs.
    • Only for the LED - to replace the thick ones?
    • Or including the MAX7219 - that's what I make
View project log
