The case is more important right?
A project log for ATLAS
Built the tricorder I actually wanted in the field: one that warns, not just measures.
apollo-timbersApollo Timbers 06/09/2025 at 01:120 Comments
I’ve always liked the idea of the Star Trek "Tricorder" one device too rule them all!, that tells you what’s really happening around you. The problem is, everything out there now is either just a collection of sensors with pretty graphs, or a phone app pretending to do more than it can. (yay its bad...)
The Innovation?
Nobody’s made something that actually tells you, simply and directly, what you need to know to stay safe or spot something weird.
So, I set a few ground rules for my design from the start:
The Case:
My first pass was just a rough 3D model—thick walls, plenty of space, making it handheld friendly. I made sure the display would be easy to read outside (so it is a monochrome OLED), buttons big enough for gloves, and everything sealed tight but easy to service.
The screen is protected buy the design as is the sensor "vent" and power switch.
What I will try to do next:
Create a sensor PCB layout and hook up to the coral, then loading up the Coral Mini with the first version of the AI model. (this step may take some time) All files, code, and build steps will be posted here as I go. If you want to follow along or build your own, everything will be on the project page or GITHUB.
This is just the start. The goal isn’t to make a flashy gadget—just a tool I wish already existed. If you have ideas, or spot something I missed, let me know. I’ll take real feedback any day.
