Here is a proper flowchart on the internals of the device, still a work in progress but getting there I may swap out the magnetometer for something that has more axis and range. Decided to go with a speaker too as it will be able to give more then beeps, may still need to add a piezo beeper for low level warnings so I don't have to wake up the AI board.
