So I was able to find one of the sensors I would like to have at the local Microcenter, The SGP30 Gas sensor. Took it home and found out it was a dud, after returning the new one started reporting right away. The following readings were a very "professional" test of me lighting a paper recipe near it lol...
This is just a prototype/get it working situation, I plan on getting all of them hooked up to a Pi Pico and working together/reporting. I then can expand the code to the display. Once all of that is goo I can look at the Sensor PCB. The switch PCB however should be able to be done sooner then later as it is relatively simple.
I had a thought that once I do have them going it may be good to record sample sets in various areas, like a forest, my lab, the kitchen and so for so I build up a data set needed to help train the AI.
eCO2: 406 ppm, TVOC: 0 ppb
✅ Air quality is excellent. No ventilation needed.
✅ No significant VOCs detected. Air is clean.
eCO2: 741 ppm, TVOC: 0 ppb
eCO2: 2595 ppm, TVOC: 397 ppb
🚨 CO₂ is dangerously high! Leave within 5 min.
eCO2: 5655 ppm, TVOC: 1810 ppb
⚠️ Chemical odors detected—address within 15 min.
eCO2: 2683 ppm, TVOC: 1219 ppb
eCO2: 847 ppm, TVOC: 586 ppb
Code...
import time
import board
import busio
import adafruit_sgp30
# Initialize I2C and sensors
i2c = busio.I2C(board.SCL, board.SDA)
sgp30 = adafruit_sgp30.Adafruit_SGP30(i2c)
# Function to classify risk level
def get_warning(eCO2, TVOC):
warning = ""
# CO₂ Alerts
if eCO2 < 1000:
warning += "✅ Air quality is excellent. No ventilation needed.\n"
elif 1000 <= eCO2 < 2000:
warning += "⚠️ CO₂ levels rising—consider ventilating within 10-15 min.\n"
else:
warning += "🚨 CO₂ is dangerously high! Leave within 5 min.\n"
# VOC Alerts
if TVOC < 500:
warning += "✅ No significant VOCs detected. Air is clean.\n"
elif 500 <= TVOC < 2000:
warning += "⚠️ Chemical odors detected—address within 15 min.\n"
else:
warning += "🚨 High VOC levels! Leave within 5 min.\n"
return warning
print("SGP30 Sensor Ready")
while True:
eCO2, TVOC = sgp30.iaq_measure()
print(f"eCO2: {eCO2} ppm, TVOC: {TVOC} ppb")
# Generate warning message
alert_message = get_warning(eCO2, TVOC)
print(alert_message)
time.sleep(1)
