1Print the details
Download the zip archive with STL files according to the version you want to build (pet_feeder_vN_STL.zip where N is the version number), unzip and extract the resulting files. Some parts need more than one. Quality and infill do not matter. I printed with a 0.4mm nozzle, 0.2mm layer height, 20-30% infill.
2Assembly
Use the assembly video if something is unclear.
3Program
All three options use ESPHome. If you have HomeAssistant and ESPHome I have nothing more to explain, if you don't then you need to install it.
4Enjoy
Enjoy.
