Context & Motivation
An engineer in Duivendrecht, near Amsterdam, wanted safe outdoor roaming for his cat Escobar.
Commercial trackers (Invoxia, Findster, Tractive, AirTags) failed due to poor coverage, high SIM fees, sluggish updates, or excessive bulk.
Chosen solution
LoRaWAN + TTN gateway
Deployed indoor TTN LoRaWAN gateway (~€70), extended range via external antenna setup (Aurel GP‑868 + cable)
Tracker hardware
Selected BroWAN Object Locator: 28 g, 540 mAh battery, movement-activated, ~8–10 hr life at 1 min intervals, 1 km range.
Cat harness modified with Velcro pockets to hold BroWAN, Findster (backup), Tile (local buzzer)
Functionality & pros/cons
LoRa sends ~50 bytes uplink per minute with GPS & battery data; TTN gateway forwards via console/API
Lacked buzzer in BroWAN; Findster & Tile added to assist locating when nearby
Setup supports low-cost transmissions over community TTN mesh with no SIM fees.
Software stack
TTN console configures device/app and byte parser.
HTTP integration pushes data to custom backend (Scala + TypeScript).
Real-time route tracking via websockets in browser
