1Instructions
- dowload STL from thingiverse (see link below)
- customise the cat part (print it in white and paint it as you/your cat like)
- connect pump with head using little tube
- fit pump inside the base
- put head on base
- fill water
- connect usb (e.g. use a powerbank)
