Environmental Temperature and Humidity Monitor
——WangChong
Introduction
Due to continuous rainy weather and large temperature differences recently, many microcontroller circuit board pins have become rusty. Therefore, placing a temperature and humidity sensor indoors is very necessary. When the humidity is appropriate, each microcontroller board can be taken out to be sun-dried to remove moisture. To prevent development boards from sitting idle forever, I took out my M61-32S-Kit and DIYed this project to meet my needs.
Parts List
Name
Quantity
Description
AI-M61-32S-Kit
1
Core control MCU
Panel Board
1
Simplifies circuit connections
Jumper Wires
Several
Circuit connections
DHT11 Temperature & Humidity Sensor
1
Detects temperature and humidity data, transmits to MCU
Sliding Potentiometer
1
Controls the brightness of the 1.8-inch SPI screen
1.8-inch SPI Screen
1
Displays temperature and humidity data
Breadboard Power Module
1
Provides power to the breadboard
Breadboard DC Power Cable
1
Supplies power to the breadboard
Electronic Components Introduction
This module accepts two power input options: USB Type-A and DC (7–12V). Using two voltage conversion chips, it can convert input voltage to 3V or 5V (selectable via jumper cap).
The DHT11 digital temperature and humidity sensor features a calibrated digital output. It contains a resistive humidity sensing component and an NTC temperature sensor. Each DHT11 sensor is calibrated in a highly accurate humidity calibration chamber. Calibration coefficients are stored in OTP memory and used during signal processing — no user recalibration required. Single-wire serial interface simplifies system integration. Compact size, ultra-low power consumption, and transmission distance over 20 meters.
A sliding potentiometer typically has three pins: one input and two outputs. When connected in series to the circuit, the varying resistance controls output through voltage division.
1.8-inch SPI Screen
SPI-driven, using 8 wires:
For brightness control: connect BL to the sliding potentiometer and the other end of the potentiometer to GND.
Pin Mapping
AI-M61-32S
DHT11
1.8-inch SPI Screen
3-Pin Sliding Potentiometer
5V (to breadboard 5V)
5V
5V
GND (to breadboard GND)
GND
GND
Middle pin (to GND)
IO13 (SCL)
SCL (clock)
IO13 (MOSI)
SDA (data)
IO12 (CS)
CS (chip select)
BL (brightness control)
Left 1
IO26
RES (reset)
IO27
DC (not used)
IO25
Signal pin
Core Code Explanation
Sending Start Signal
bflb_gpio_set(gpio, DHT_PIN);
bflb_mtimer_delay_ms(50);
bflb_gpio_reset(gpio, DHT_PIN);
bflb_mtimer_delay_ms(20);
bflb_mtimer_delay_us(30);
Receiving DHT11 Response
bflb_gpio_init(gpio, DHT_PIN, GPIO_INPUT | GPIO_PULLUP | GPIO_SMT_EN);
while (bflb_gpio_read(gpio, DHT_PIN) == 1) {}while (bflb_gpio_read(gpio, DHT_PIN) == 0) {}while (bflb_gpio_read(gpio, DHT_PIN) == 1) {}
Reading DHT11 Data
uint8_t data[5] = {0};for (int i = 0; i < 5; i++) {
    data[i] = 0;
    for (int j = 0; j < 8; j++) {
        if (bflb_gpio_read(gpio, DHT_PIN) == 1) {
            data[i] |= (1 << (7 - j));
Parsing DHT11 Data (No Checksum)
uint8_t humidity_integer = data[0];uint8_t humidity_decimal = data[1];uint8_t temperature_integer = data[2];uint8_t temperature_decimal = data[3];
float humidity = humidity_integer + (humidity_decimal / 10.0);float temperature = temperature_integer + (temperature_decimal / 10.0);
Displaying Temperature and Humidity on the 1.8-inch SPI Screen
LCD_ShowString(1, 50, "Temperature:", BLACK, WHITE, 12, 1);
LCD_ShowFloatNum1(73, 48, temperature, 4, RED, WHITE, 16);
LCD_ShowString(1, 80, "Humidity:", BLACK, WHITE, 12, 1);
LCD_ShowFloatNum1(73, 78, humidity, 4, RED, WHITE, 16);
Display Example
Minimum screen brightness (off)
Normal brightness
 DHT11数据手册.pdf
DIY_Project.zip
helloworld_bl616.zip
Notes:
You can manually control the screen brightness via the sliding potentiometer.
The DHT11 sensor shows good accuracy and stability in daily use — tested continuously for several days.
