- Powered by a Raspberry Pi Zero 2W
- 2.8" or 2.4" SPI TFT display (ST7789) with 320x240 resolution and PWM brightness controller.
- Two 2400mAh 18650 cells in serie (2S 8.4 Volts).
- PAM8403 module using a notebook speaker.
- Custom low-pass audio filter transforms the Pi’s PWM output into proper audio.
- Added a 3.5mm headphone jack and a volume knob.
- RCA video output wired to the top of the console.
- Front panel includes extra buttons for X, Y and four rear buttons (L/R-style).
- All parts held in place with 3D-printed supports, M2 brass inserts, and machine screws.
- Bluetooth controller support and Wi-Fi enabled.
- Can charge while playing.
- Has its own PCBs to avoid wiring a lot.
repkid
JohSchneider
Rodmg
retrobyte
thanks
