A little Mixture of some unused Prototypes.
Printed Circuit Boards made with slimy Toxic theme. I have Been messing around with AV gear a little bit. This is a combined effort to dive a little bit into AV modulation with some of the extra Circuits. It is on a Wooden frame board and can be swapped out with other setups. I think it is a good way to use up some of the Extra more borked PCBS that require extra modification. But are still very useful.
*Main oscillator and LFO
APC Semi-Patchable Synthcard
https://hackaday.io/project/196231-atari-punk-console-semi-patchable-synthcard
*Analog Video Patch and Glitch
-Pick and mix AV synth card
https://hackaday.io/project/197473-altoids-style-tin-crt-video-glitcher
Been getting this little Project viewable. Still gotta Figure out LibreElec version or kodi out. My Raspberry pi 2 is in trying times to get both HDMI and AV out of the 3.5mm Jack. I will probably use a Raspberry pi 3 variant. Having Wifi/Bluetooth would be useful and having a little bit more power might be a good thing Since this is just going to be used for basic analog AV.
