DIY PWM-Controlled IKEA TILLREDA Induction Cooktop
Modifying a 2kW induction cooktop for precise control via PWM, enabling integration into an automated beer mashing and cooking system.
Public Chat
This project adds remote control functionality to an existing IKEA TILLREDA induction cooktop, enabling it to be integrated into a homemade beer mashing and cooking machine . See youtube video and hackaday project links below The goal was to take advantage of this affordable and reliable cooktop for automated temperature control, essential in brewing processes. To achieve this, the cooktop’s serial communication protocol was reverse-engineered, and a custom PCB was added internally. The modification allows external control—while preserving full manual operation when not connected to the brewing system. See youtube video : https://youtu.be/v5XNNvFhkFM
⚠️ Warning:
This project is provided for educational and experimental purposes only.
Modifying electrical appliances—especially high-power devices like induction cooktops—carries significant risk, including electric shock, fire, injury, and property damage.
If you choose to replicate or adapt this project, you do so entirely at your own risk. Ensure all work complies with your local electrical safety regulations and building codes.
Do not attempt this project unless you are competent and qualified to work with high-voltage electrical systems. The internal electronics of the cooktop are not isolated from mains voltage. This means that touching components operating at low voltage (e.g., 5V logic circuits) may result in electric shock. Connecting a non-isolated oscilloscope to the cooker while it’s powered can cause serious damage—to both your equipment and yourself.
Enough disclaimers for now—you get the picture!
I was looking for a cheap heating solution for my DIY beer mashing and cooking machine.
My first attempt was a standard resistive cooktop—but it had way too much temperature overshoot during regulation. I then tried an immersion heater, which was fast, but unfortunately, grain kept sticking to it and burning.
Eventually, I found a relatively inexpensive (€40) 2 kW induction cooktop at IKEA. I knew that controlling it automatically wouldn’t be as straightforward as with a resistive cooktop, but a quick search online showed that others had hacked similar devices before—for example,
I probably should have watched the whole video before buying it, because it turns out the hack was never completed. Still, it gave me a decent idea of what to expect.
Then I came across this project on Hackaday, which explored a similar Amazon-branded induction cooker. Interestingly, it uses the same 10-byte communication frames, suggesting these devices might share a common platform or manufacturer.
Unfortunately, that project was also left unfinished.
So, I decided to reverse-engineer the IKEA cooktop myself and finally move forward with my beer machine!
Gerber_PCB_inductionCookerDriver.zip
EasyEDA gerber export. Note : I etched the PCB myself as a prototype. This means not all gerber layers are verified , and footprints might not be ideal. Also see the note in the schematic about adding some more lines to the programmer connector
x-zip-compressed - 33.49 kB - 02/22/2026 at 12:33
Download
inductiondriver.zip
Zipped source code for the ATmega328PB. Written in C using the Arduino IDE.
x-zip-compressed - 7.34 kB - 06/22/2025 at 15:58
Download
PCB2.svg
top layer layout of the pcb ( bottom layer = complete copper.
svg+xml - 127.93 kB - 06/21/2025 at 20:17
Preview
Schematic.pdf
Adobe Portable Document Format - 73.93 kB - 06/21/2025 at 20:17
Preview
  • Power measurements
    Fieldman • 06/22/2025 at 17:37 • 0 comments
    The table below shows the mains power consumption of the induction cooktop at various internal power levels (5-bit values), along with how I mapped those levels to a corresponding PWM range.
    To achieve power levels lower than the cooktop's minimum setting (Level 1 ≈ 170 W), I implemented time multiplexing for some PWM values. For example, a PWM value of 8% results in 5 seconds off followed by 10 seconds at power level 1, effectively lowering the average output.
    Note that the power levels are neither linear nor logarithmic, but they are sufficiently consistent for the needs of my brewing application.
  • Embedded Code for Arduino
    Fieldman • 06/22/2025 at 15:57 • 0 comments
    The ATmega328PB on this board is programmed using the standard Arduino IDE.
    To compile code for this specific microcontroller, you’ll first need to install the MiniCore board package, which adds support for the ATmega328PB and similar chips.
    Once MiniCore is installed, burn the bootloader using the appropriate settings—after that, you're ready to upload the firmware as you would with any Arduino project.
    See the included source code for details.
  • Circuit Schematic & PCB
    Fieldman • 06/21/2025 at 20:16 • 0 comments
    See the included schematic and PCB layout.
    The circuit is intentionally simple, using components I already had on hand. The most critical design requirement was to maintain SELV (Safety Extra-Low Voltage) isolation between the opto-coupler input and the rest of the PCB, as well as the cooktop’s internal electronics.
    The PCB was home-etched, which is the fastest and easiest method for a simple board like this. It features a single routed top layer and a solid ground plane on the bottom, which simplifies etching.
    To protect against moisture or condensation, the board is finished with a conformal coating.
    A 3.5mm jack is used as the input for the external PWM control signal.
    For secure installation inside the cooktop, the PCB is mounted using a custom 3D-printed base.
  • Reverse engineering the serial protocol.
    Fieldman • 06/21/2025 at 18:03 • 0 comments
    Using an isolated oscilloscope, it became clear there's a master/slave serial communication setup between the front panel (master) and the power PCB (slave).
    • The communication uses standard 9600 baud, 8 data bits, no parity, 1 stop bit, and LSB-first format.
    • The front panel transmits a 10-byte message every 100 ms.
    • The power PCB responds with a message of equal length.
    You might wonder why such a simple application needs this much data. The answer is probably a mix of redundancy/error correction, and the fact that modern designers don’t worry too much about a few extra bytes.
    Analysis: Front Panel → Power PCB (Red Trace)
    Here’s an example of the message when the power level is set to 0.
    These are the telegrams corresponding to each possible front panel state (with byte 0 sent first).
    I initially tried asking GPT-4 to decode the structure, but that didn’t lead anywhere useful. So, I went old school: pencil and paper. The result?
    A lot of fixed values and redundancy, just as expected. For example: some values are inverted (~) as basic checksums.
    There are 5 bits used to encode the power level, allowing for up to 32 distinct values. This means the system is technically capable of finer power control than what the front panel offers, which only allows selection of levels 0 through 9.
    However, there are two important limitations:
    • The lowest power level available via the protocol still corresponds to front panel level 1, so there's no way to achieve a power output lower than that baseline.
    • Interestingly, front panel level 9 corresponds to a power level value of 20 (decimal) in the protocol, indicating that only a portion of the available range is used.
    Analysis: Power PCB → Front Panel
    This direction was a bit trickier. Some of the values changed with every transmission.
    Below is a capture of 15 sequential messages ( OFF state).
    After a beer and some focused thinking, here's what I figured out:
    • The 4 error bits appear to encode error conditions.
      • For example, error1 seems to indicate “no pot detected” on the cooktop.
      • I didn’t dig much deeper, since the PWR bit turned out to be a reliable indicator of whether power is being delivered or not.
    Parameter Cycling Logic
    One part of the message changes continuously: every transmission includes one of five different data parameters. This is controlled by 3 bits C2:C1:C0, which cycle through: 0 → 1 → 2 → 3 → 4 → 0 → ...
    Each parameter is sent as a 12-bit value dat11:dat0
    Reverse-Engineering the 5 Data Parameters
    After some experimentation, here’s my best guess at what each parameter represents:
    Parameter Likely Meaning
    Data 0 : Unknown
    Data 1  : Temperature of something
    Data 2 : Temperature of something else
    Data 3 : Voltage indication ? (drops slightly as power increases)
    Data 4 : Power indication
    However, my interface doesn’t depend on these values. It simply checks that the PWR bit is in the expected state (i.e., ON when power is requested).
    It’s worth noting that the power PCB has solid self-protection features. For example, it automatically drives the cooling fan when necessary—independent of external control.
  • Conceptual Solution
    Fieldman • 06/21/2025 at 15:07 • 0 comments
    There were two main approaches I could take:
    Option 1: Hijack the Capacitive Buttons
    This involves adding electronics that take over the touch buttons. Since the device behaves autonomously (e.g., it automatically switches off after sitting at power level 0 for a while), I’d also need to read all the LEDs—including the 7-segment display—to monitor its current state and react accordingly.
    Pros:
    • Straightforward—no need to reverse-engineer the communication protocol
    • Built-in safety features remain fully active
    • The display still shows the current power level
    Cons:
    • Requires careful tuning to reliably trigger the touch sensors
    Option 2: Intercept the Communication Between Control and Power Boards
    This means placing a microcontroller between the control PCB and the power PCB. It can pass through normal communication during manual use, and take over when automated PWM control is needed.
    Pros:
    • Offers more direct and flexible control
    • Potential for finer-grained control beyond the default 0–9 power levels
    Cons:
    • Requires reverse-engineering the communication protocol
    • Need to fully understand the built-in protection mechanisms
    At the time, Option 2 seemed the most promising—or at least, the most fun from an electronics perspective—so I went with that.
    Here’s a photo of the final working setup. More details to follow!
  • ⚠️ Safety Disclaimer
    Fieldman • 06/21/2025 at 14:05 • 0 comments
    ⚠️ Disclaimer
    The author is not responsible for any injury, damage, loss, or legal consequences resulting from the use or misuse of this information.
    This project is not affiliated with, endorsed by, or supported by IKEA in any way. All product names and trademarks are the property of their respective owners.
View all 6 project logs
Fieldman wrote 03/20/2026 at 16:48 • point
Thank you!
Normally any Arduino should do.  Only standard features are used : serial port , timer and a few GPIO. And limited processing power is needed. Some code changes may be necessary, depending on the exact processor on the board.
Cat wrote 03/19/2026 at 04:47 • point
This is VERY impressive; thank you!
I am wondering if you needed all the features that the 328PB offer, or could you have used a small Arduino mini/micro or such.
Per Jensen wrote 07/26/2026 at 19:43 • point
I'm pretty sure it was because that's what he had laying in the parts bin.
