Features
- Use latching relays as the core mechanism for signal routing to avoid continuous standby power consumption and eliminate the operational drawbacks of manual knife switches.
- As small as possible, the final product will be enclosed in a 26×26×80 mm casing.
- It contains a built-in rechargeable lithium battery. To ensure shipping friendliness, an LIR1452 coin cell is used.
