Project Log #3 – Choosing a Display: Original vs. HDMI
A project log for Nokia N97 Cyberdeck Resurrection
Rebuilding a Nokia N97 into a pocket Linux cyberdeck with SBC, HDMI display, original keyboard, and touchscreen.
retrobyteretrobyte • 06/28/2025 at 11:34•0 Comments
This update focuses on the most visual part of the cyberdeck: the screen.
The Nokia N97 originally used a TPO LTJ035L001A panel — a 3.5″ RGB interface TFT with no onboard controller. It connected via an FPC ribbon to the mainboard through the X4400 connector. While functional in its time, it’s not Pi-friendly: it lacks HDMI, SPI, or even I²C, and needs a parallel RGB driver (or something like an RTD2660H).
📸 Size Matters: Comparing Original vs. HDMI
I’ve been testing a 3.2″ HDMI TFT panel (Waveshare / Inanbo) as a replacement. I’ve included comparison shots of:
Surprisingly, the new display is almost a perfect mechanical fit — slightly smaller in width, which helps with routing, and thin enough to slide into the original mounting location with minimal modification.
✅ Why HDMI Wins
🔧 Notes
🛠 Next Up
Original LCD
Inanbo t32chrip51 v19
Original Left replacement Right
