Project Update 9: Display Finally Responding—but Still a Blank Canvas
A project log for Nokia N97 Cyberdeck Resurrection
Rebuilding a Nokia N97 into a pocket Linux cyberdeck with SBC, HDMI display, original keyboard, and touchscreen.
retrobyteretrobyte • 08/23/2025 at 19:35•0 Comments
I finally got the replacement display to wake up and show actual colour output—but it’s only showing a vertical colour bar, not a full image yet. Still progress!
What’s Working
That’s a big step over “nothing at all.”
Current View: Just a Vertical Bar
Despite the screen lighting up, the output remains a vertical bar—static or shifting—but no actual framebuffer image is rendering.
This scenario typically points to one of two culprits:
  1. Timing/synchronization mismatch—porch widths, active edge polarity, or sync pulses might still be slightly off.
  2. Data bit misalignment or wiring error—only one set of colour bits (e.g., blue) is being correctly mapped, while red/green are getting lost or misinterpreted.
Next Steps on the To-Do List
Here’s the investigative roadmap I’m following to resolve it:
** 1. Double-check timing configuration** Align the Raspberry Pi’s DPI parameters (hfront / back-porch, hsync, vsync, pclk) against known working examples from similar screens
** 2. Revisit wiring and bus mapping** Ensure the display’s RGB lines are properly connected:
** 3. Explore differential init commands** Compare init sequence with any other similar panels that I can find, their may just be gold
link to frambuffer video
https://cdn.hackaday.io/files/2033918701880544/LCD_frame_buffer_responce_to_col.mp4
link to current semi working INIT
https://cdn.hackaday.io/files/2033918701880544/HV_mode.ino
