Hackaday.io Hackaday.io
Sign up Log in
Raspberry Pi in the stratosphere
Image and data capture in the stratosphere with Raspberry Pi Zero 2W and Pi Camera for high-altitude science missions.
elvisandres18elvisandres18
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
111
2
1
2
Team (1)
  • elvisandres18elvisandres18
Join this project's team
  • EMIDSS-5
  • RASPBERRY_PI
hardware
ongoing project
This project was created on 07/04/2025 and last updated 7 days ago.
Description
My project focuses on developing a low-cost data and image acquisition system using a Raspberry Pi Zero 2W and a Raspberry Pi Camera V3. The entire system was assembled inside a 3D-printed PLA plastic enclosure, without thermal insulation, to maintain simplicity and accessibility in the design. This module was successfully launched into the stratosphere aboard a NASA scientific balloon from Fort Sumner, New Mexico, as part of the EMIDSS-5 program. The main goal of the system is to demonstrate that it is possible to capture high-quality images and collect relevant environmental data from the stratosphere using affordable and compact technology—ideal for future educational, scientific, or CubeSat missions. Despite being exposed to extreme conditions, including temperatures below -50 °C and low atmospheric pressure, the system operated reliably throughout the mission.
Details
Files
JPEG Image - 580.96 kB - 07/09/2025 at 04:46
Preview
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Ken Yap wrote 07/04/2025 at 06:48 • point
That's good to know, that widely available electronic modules can be so robust, 👍
elvisandres18 wrote 07/09/2025 at 04:42 • point
Absolutely! It’s great to know that there are low-cost alternatives that allow us to be part of this field of engineering without having to spend a lot of money. Best regards!
Pico WiFi HAT attaches to the back of Raspberry Pi and connects to 2.4GHz wireless networks using an ESP8266 high integration wireless SoC.
Project Owner Contributor
Access Wi-Fi Features on Raspberry Pi Pico
undefined
Multispectral (LWIR, NIR, Vis, UV) Imager and Imaging (NIR-Vis-UV) Polarimeter Based on the Raspberry Pi
All-Mode Raspberry Pi Imager
david-prutchiDavid Prutchi
data.sparkfun.com is an open source IoT platform. This is about pushing data from Raspberry Pi to data.sparkfun.com using Python.
Raspberry Pi : push data to data.sparkfun.com
alfredcAlfredC
Xively is an IoT platform. This is about pushing data from Raspberry Pi to Xively using Python.
Raspberry Pi : Push data from RPi to Xively
alfredcAlfredC
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi in the stratosphere", please tell us the reason.
Send message
Remove Member
