Dual voltage supply from a single input
A project log for The (analog) 1Hz sinewave generator
The most ridiculous, overengineered, stupid way to create a 1Hz sinewave using OP-amps ..... (and a timer)
phil-weaselPhil Weasel • 07/11/2025 at 05:22•0 Comments
So to make my life easier, i want to only use one power supply. Thus i need to generate the negative voltage.
Get ready for some op-amp magic:
By setting the positive input to roughly 1/2 Vin and creating a feedback loop, i can use the output of the opamp as a "virtual ground".
MAGIC!
Adding a push pull transistor pair further increases the current capability of the output. However, this circuit is still pretty limited current wise but fine for our puroposes.
-> Just make sure to also use the virtual ground for any scope measurements
Adding this to my breadboard setup, it still works super fine
