The frequency counter
A project log for The (analog) 1Hz sinewave generator
The most ridiculous, overengineered, stupid way to create a 1Hz sinewave using OP-amps ..... (and a timer)
phil-weaselPhil Weasel • 07/15/2025 at 10:59•0 Comments
To be able to compare two frequencies we first need to convert a frequency to a voltage.
One might just use an RC filter .... but at 1Hz thats not feasable.
So i came up with a different approach.
I take the positive part of the squarewave output, and charge a capacitor. On the negative half i discharge it.
Higher frequency = less time to charge = lower voltage
Lower frequency = more time to charge = higher voltage
Easy, right?
On the output we get this.
Now we average this output with another I-controller integrator.
No we do the same thing with our reference frequency
