Closing the loop
A project log for The (analog) 1Hz sinewave generator
The most ridiculous, overengineered, stupid way to create a 1Hz sinewave using OP-amps ..... (and a timer)
phil-weaselPhil Weasel • 07/15/2025 at 11:07•0 Comments
I went out of space on my perfboard .... and blew my opamp power supply twice .... and broke a thing or two ... maybe even twice.
So i continued like this:
Building the reference frequency from my oscilloscope and closing the loop.
I subtract the voltage from the oscillator from the reference and get an error.
Another integrator and i added an offset so it wont get stuck on startup.
The result then gets fed into the main oscillator as a set voltage.
And .....
IT ACTUALLY WORKS I CANT BELIEVE IT.
Yellow = Triangle from oscillator
Blue = Control voltage to oscillator
After a few seconds the output actually settles to the given reference frequency i cant believe it.
Is it accurate tho? well ... no, not yet .... but we will get to that....
