Zumo-Jetson
a robot that learns and recognizes patterns on the go.
Public Chat
The robot is based on Jetson Nano. The demo script reads the camera frames. Masks the blob, here green (for recognizing) and blue (for learning), using color based segmentation by converting the frames to HSV color space. A check is applied to avoid blobs overlapping with the edge of the frame. The masked image is then inputted to pyrebel which learns/recognizes the blob (using https://github.com/ps-nithin/pyrebel#5-pattern-recognition-demo). Here the recognized symbols are mapped with audio recordings made during learning the pattern. The recorded audio is played back during recognition.
  1. The robot uses an Arduino Nano RP2040 Connect as motor controller. It is connected to jetson nano over usb. The arduino firmware has common functions to drive motors and leds connected to it. For example, sending "blinkledwhite_1" over serial to the arduino turns on the white led.
  2. Three leds (white, green and blue) connected to the arduino shows the current state of the program. The white led blinks when the program is ready to accept input. The green led blinks when a green blob is detected in the input and the program tries to recognize the input. The blue led blinks when a blue blob is detected in the input and the program tries to learn the input. When both the green and the blue led blinks it indicates that both green and blue blobs are present in the input.
  3. A speaker and microphone is connected to jetson nano over usb. A Raspberry pi camera module v2 is connected to csi camera port of the jetson nano. Wireless connectivity nor internet is needed to run the program but is used for setting up jetson nano.
Patterns
The program can handle both green and blue patterns simultaneously. These different combinations of green and blue patterns can occur,
1. Only green patterns are present in the input.
In this case only recognition happens, either in 'text', or 'audio' channel. Channel having higher weightage is selected.
2. Only blue patterns are present.
In this case only learning happens. Since there are no green patterns, all the learning happens in 'audio' channel only. If there are multiple blue patterns, each constituent blue pattern has to be learned seperately in 'audio' channel before learning the pattern as a whole.
3. Input contains a combination of green and blue patterns.
In this case both learning and recognition happens. The blue patterns are learned with the symbol recognized from reading the green patterns. Both recognizing green patterns and learning blue patterns takes place in channel 'text'.
Pre-training
Letters of the English alphabets are pre-trained to provide a vocabulary for learning more complex patterns. The pre-trained letters can be relearned later to update the knowbase with different variations of the pre-trained letters as required.
Motors
The motors are controlled by four keywords in channel 'text'.
1. 'fw' for moving forward.
2. 'bw' for moving backward.
3. 'sc' for spinning in clockwise direction.
4. 'sa' for spinning in anti clockwise direction.
These keywords can be reassigned later to any arbitrary pattern you like by relearning.
Channels
When an image is learned its signatures are stored in channel 'text'. When a recording is made the signatures are stored in channel 'audio'. During recognition, different symbols may be recognized for each channels. The symbol from channel with higher weightage is selected.
zumo-jetson-pcb.kicad_pcb
PCB for robot controller board
kicad_pcb - 101.27 kB - 08/10/2025 at 05:51
Download
zumo-jetson-pcb.kicad_sch
Schematic for robot controller board
kicad_sch - 87.33 kB - 08/10/2025 at 05:51
Download
zumo-jetson-pcb.kicad_pro
kicad_pro - 15.00 kB - 08/10/2025 at 05:51
Download
  • 1 × Zumo chassis (Pololu - Zumo Chassis Kit (No Motors) https://www.pololu.com/product/1418) act as the main chassis.
  • 2 × Motors (Pololu - 298:1 Micro Metal Gearmotor HPCB 6V https://www.pololu.com/product/3069)
  • 1 × Motor driver (Pololu - DRV8833 Dual Motor Driver Carrier https://www.pololu.com/product/2130)
  • 1 × Voltage regulator (Pololu - 5V Step-Up/Step-Down Voltage Regulator S9V11F5 https://www.pololu.com/product/2836)
  • 1 × Arduino Nano RP2040 connect as motor controller
View all 11 components
  • 1
    Build
    You could hook up the wires using schematic or there is a robot controller board (please find design files in the files section or on github)
  • 2
    Setup
    Tested to run on a Jetson Nano with Jetpack 4.6.1.
    1. Update packages
      sudo apt update
      sudo apt upgrade
    2. Install jetson-utils https://github.com/dusty-nv/jetson-utils
    3. Install miniforge with https://github.com/conda-forge/miniforge#unix-like-platforms-macos-linux--wsl
      Numba is installed inside miniforge environment.
      Run the following commands to install numba,
      source $HOME/miniforge3/bin/activate
      conda install python=3.8
      conda install -c numba numba
      Copy jetson-utils library files from /usr/lib/python3.6/dist-packages/ to $HOME/miniforge3/lib/python3.8/site-packages
      python3 -m pip install pyserial
      python3 -m pip install scipy
      python3 -m pip install sounddevice
      sudo apt install libportaudio2 espeak-ng
    4. Install pyrebel
      cd
      git clone https://github.com/ps-nithin/pyrebel
      cd pyrebel
      python3 -m pip install .
      Patterns can also be learned using pyrebel/demo/pyrebel_main_learn_multiple.py (https://github.com/ps-nithin/pyrebel#5-pattern-recognition-demo).
    5. For example, images in zumo-jetson/scripts/images/train-hand/ are learned to learn English vocabulary.
      python3 pyrebel_main_learn_multiple.py --learn images/train-hand/
      You may also need to change the microphone and speaker settings.
  • 3
    Running the script
    1. Demo script 1 - Single pattern
      cd
      git clone https://github.com/ps-nithin/zumo-jetson
      cd zumo-jetson/scripts
      sudo $HOME/miniforge3/bin/python3 pyrebel_main_learn_sound_jetson.py --camera 1 --user=$USERNAME
    2. Demo script 2 - Multiple patterns
      cd
      sudo $HOME/miniforge3/bin/python3 pyrebel_main_learn_sound_jetson_multiple.py --camera 1 --user=$USERNAME
View all 4 instructions
