11. Gather Your Parts & Tools
Components:
- 12 V DC power supply (or 13 V battery)
- LED (5 mm)
- Electrolytic capacitor (100 µF)
- Resistors: 2 × 10 kΩ, 1 × 3.3 kΩ
- Potentiometer (4.7 kΩ)
- TYN612M SCR
- BC547 NPN transistor
- NTC thermistor (10 kΩ)
Tools & Accessories:
- Multimeter (for calibration)
- Wire cutters/strippers
- Hook‑up wire / jumper cables
- Solderless breadboard (or perfboard + soldering iron)
22. Populate the Breadboard
- Place the Thermistor: Insert your NTC into one row.
- Add Q1 (BC547): Place the transistor so its flat face points toward you; note Emitter (E), Base (B), Collector (C).
- Mount the SCR: Position the TYN612M nearby, aligning its pins (Anode, Cathode, Gate) per your schematic.
- Install the Potentiometer (RV1): Put the three leads across three consecutive breadboard rows.
33. Wire the Bias Network
- Base Bias for Q1:
- Run R1 (10 kΩ) from +12 V rail to Q1’s base row.
- Run R2 (10 kΩ) from +12 V rail to Q1’s base row.
- Connect the wiper of RV1 (4.7 kΩ pot) between those same two 10 kΩ resistors and to Q1’s base.
- Thermistor Connection:
- One lead to Q1’s base row.
- The other lead to ground rail.
- Base Bias for Q1:
44. Gate & LED Circuit
- SCR Gate Resistor: Place the 3.3 kΩ resistor from +12 V rail to the SCR’s gate pin.
- LED & Series Resistor:
- Connect the SCR’s cathode to ground.
- From the SCR’s anode, run the LED (with its built‑in resistor or an external ~220 Ω resistor) to +12 V.
55. Add the Supply Smoothing Capacitor
- Tie the 100 µF electrolytic capacitor between +12 V and ground as close to the transistor/SCR as possible to filter noise.
66. Power Up & Initial Calibration
- Attach your 12 V supply (observe polarity).
- Using a multimeter, adjust RV1 until Q1 just barely conducts (Collector sits near 0 V). This keeps the SCR gate grounded and the LED off at room temperature.
77. Functional Test
- Cold Test: The LED should remain off at ambient temperature.
- Heat Test: Gently warm the thermistor (e.g., with a hair dryer or hot water) and watch for the LED to snap on around ~90 °C.
- Reset: Cut power to reset the SCR latch and repeat as needed.
88. Troubleshooting Tips
- No LED when hot? Verify your gate resistor and SCR pinout; ensure RV1 is not set too high.
- LED always on? RV1 may be set too low—reduce the base bias so Q1 stays firmly ON at room temp.
- Voltage sag: If you used a 9 V battery and the circuit refuses to trigger, switch to 12 V.
Harshit Mishra
